Results 1 to 20 of 27
Thread: 2002 Chevy Camaro Z28 Tuning Help
    Mar 2024
    16
    I have a 2002 Chevy Camaro Z28 that I just put a BTR LS1 Stage 3 Cam (231/244 .630"/.615" 112.5+2.5) in with supporting mods. Now I'm starting to tune and wonderings if anyone has a tune I could use for a baseline for idle and so I can start to tune because I'm struggling too. I'm completely new to tuning, any Help is greatly appreciated, and thank you in advanced.
    13,582
    Post the tune you have now.
    405
    2,341
    Auto or manual? If auto I hope you put in a minimum 3600 stall converter with that cam.
    Mar 2024
    16
    I will post the tune in a bit but it is a Auto with a 3200 stall?which FTI said it was ok but if I need a 3600 ig I will
    Mar 2024
    16
    As Found 31624.hpt
    This is the tune that is on the car from the previous owner.
    Indiana
    329
    Quote Originally Posted by Evan Burghart View Post
    As Found 31624.hpt
    See if this will get you idling. Just some basic rough adjustments for that cam size.
    "I don't care how it runs as long as it chop chops at idle"
    Mar 2024
    16
    Quote Originally Posted by horsepowerguru427 View Post
    Thank you very much I will flash the tune and start it up when I get back to the car on Friday
    Mar 2024
    16
    I put this tune on it but it was about the exact same as it was before is there something I could be doing wrong?
    13,582
    You need to post some data logs so we can see what is going on.
    We also need to know what supporting mods means. Is that headers and full exhaust, stock intake manifold or aftermarket? Stock injectors or aftermarket?
    Because there is no way stock injectors will support that camshaft.
    Mar 2024
    16
    idle 1.hplidle 2.hpl
    here are 2 log its idling now... the mods on the cars are headers, true duals, "caddy lifters", pushrods, .660 valve springs, timing set, high pressure oil pump, but stock injectors because i was told they would be find but what would you recommend, i hope i didnt forget anything
    405
    2,341
    2002-04 Z06 makes 405 HP with the same injectors. My own 99 F-body made 400RWHP with those 02 injectors and ran high 11s with a 224/228 cam shifting at 6500 rpm. They are rated at 28.7 and a little higher in the Vettes. While they are at their limit there they will work.
    Mar 2024
    16
    Ok thank you, what do you think i should do based on the 2 logs i posted above.
    Mar 2022
    Indiana
    2,979
    You need to get VE correct. The difference between MAF and DynAir shows that the VE table is being referenced. In fact, you will have better results running the SD OS.
    Over/underspeed idle spark corrections are too high. Definitely don't want 4 degrees for 0 rpm error.
    Injection Timing Normal table should be adjusted for your cam.
    And why is Torque Management>Maximum Torque>vs. RPM zeroed? Set it to stock unless you have a TCC with a multi-disc clutch.
    405
    2,341
    Because it is a F-body not a truck/suv. That is how the stock table is on those.
    Mar 2022
    Indiana
    2,979
    Ah ok.
    Mar 2024
    16
    So do I need to change it or am i good?
    Mar 2022
    Indiana
    2,979
    You're good on that one. Sorry for the confusion.
    Mar 2024
    16
    idle 7.hplStartUp changes2 32324.hpt
    i have made some adjustment from suggestions and i keep applying the MAF error every time but wondering what should be next. thanks for help in advanced
    Mar 2022
    Indiana
    2,979
    Seriously, tune the VE table. Look what happens at the idle dip. See the difference in MAF and DynAir? See what the O2 traces are doing?
    Mar 2024
    16
    OK i think i see what you are saying i didnt have dynair on my chart like you do thank you i will try to figure it out.
