MED17.1 Boost Request Procedure
Hello, I'm having difficulties with a 2012 GTI where I simply am struggling with producing more boost. Customer switched from K03 to the F23T so I know it is well capable of more. I understand that you may command boost through the torque and airmass requests as well as being able to adjust PR limits. However, I've spent the past day adjusting every parameter that makes sense to me as well as every parameter I've seen mentioned when doing research and have had no luck with any outcomes. I don't produce any more or less boost than I did before, powerband also feels the same.
I would greatly appreciate any help or advice on why I'm running into this issue, or what parameters i need to adjust and how they need adjusted.
