Results 1 to 5 of 5
Thread: Idle tune need help
    May 2023
    12
    Idle tune need help
    So I have this gen 4 5.3 stock truck injectors, intake manifold, TS Low lift stage 2 cam, maf 213-4222. not sure what other detail would be important but I modified the tune to get it running and it starts for a few seconds and it dies, if I play with the throttle I can keep it running and after a little time it stays running at idle. I have a wide band O2 and seems very rich not sure if that is my issue but I don't know much about tunning and don't want to go crazy with the tune. I will attach the tune and two log if someone can check them out and give me their opinions that would be much appreciated.
    samurai 2.hplsamurai1.hplSamuraiidle-idle new 2.hpt
    Nov 2017
    1,464
    And this is a swap vehicle?
    Never mind, this is the Frankenstein truck.
    May 2023
    12
    is she famous now?
    Advanced Tuner Cringer's Avatar
    Aug 2021
    Somewhere smoothing your VVE table
    514
    Quote Originally Posted by toroz06 View Post
    This should help...but she is looking really lean. You will need to add fuel.
    Samuraiidle-idle new 2 - 1.0.hpt
    A standard approach will give you standard results.
    My Tuning Software:
    VVE Assistant [update for v1.5]
    MAF Assistant
    EOIT Assistant
    May 2023
    12
    Quote Originally Posted by Cringer View Post
    Wow I was way off I thought I was rich! Thanks for you input
