Results 1 to 3 of 3
Thread: 2008 Silverado Low Power
    Mar 2024
    Texas
    2
    I've just finished getting my 2008 silverado 1500 installed with a 5.3 liter, 4l60 trans, with 4.10 gears. I've got a LS9 cam, 3" headers, 3" exhaust, TBSS intake 90mm TB, 2800-3000 stall converter. I've got a tune in it that has a great top end charge starting around 3k-3500 rpm. It's a dog up to that point. I've seen older threads on this, but I can't open the attachments that seem to correct this issue. I'm guessing I need to check my timing down low, but is there anything else I can check to get more power out of the program? Thank you in advance for any help with this. I'm very new to the programming side of this build.
    13,565
    Terrible camshaft choice without a blower. So many better camshafts that will actually make power down low.
    Always post your tune and logs. And I hope you have a wideband on this engine.
    7,641
    The LS9 cam's whole reason for existing is to drastically limit low-end torque (for both warranty claims and traction reasons) in the original positive displacement blower application. The same 211/230 duration but on a 112 or 110 lobe separation angle (or even 108... 107... 105) could make something like 100 lb-ft more torque under 3500-4000 on a N/A engine.
