Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
Thread: OT Need help lighting my turbo up
    2,866
    Fine try it.
    A theory will get you started.. Trying it will prove it.
    Tuner at PCMofnc.com
    2,866
    Where did I say to add timing?
    Mar 2022
    Indiana
    3,003
    Deleted my comment. It's not worth arguing about. Just the one will do. Need an airflow channel.
    5BA8
    3,465
    Pictures of manifold, hotside, turbo mount/placement? There's a lot to be said about placement, hotside, etc. and turbo efficiency.
    Most of the time I prefer to tune turbo setups to maximize NA power. That seems to be the best overall approach to building boost. Retarding timing will increase your exhaust temps but at the expense of making the engine feel underpowered. Its a completely different scenario on a trans brake so can't really use the same approach for a normal street driven application.
    email=[email protected]
    Jul 2020
    VIC Australia
    1,180
    Hey Ed, she's bone stock on the manifolds.
  6. #26
  7. #27
    Jul 2020
    VIC Australia
    1,180
    Lol, been there done that. Embarrassing
  8. #28
    7,837
    Me too... "I'm fine, just go around... just go, go please, I DIDN'T HIT ANYTHING JUST GO, JESUS..."
    edit: Dude that turbo's not much bigger than like Honda D16 stuff, you shouldn't be having spool issues.
  9. #29
    Jul 2020
    VIC Australia
    1,180
    I'm putting it back on the hoist tomorrow to have a look. I took measurements last time of preload, i'll dig that up to see if somethings moved. While I'm there i'll check if the wastegate is sealing.
    I've got a 3582 that came off it and ran sweet. Bloody tempted to through it back on.
  10. #30
    Mar 2022
    Indiana
    3,003
    Yeah no kidding.
  11. #31
    Jul 2020
    VIC Australia
    1,180
    At what point should I disclose the turbo is a China clone
  12. #32
    Mar 2022
    Indiana
    3,003
    Shitty bushings and clearances? Not gonna lie my first thought was that, but you gave the PN and it said Garrett.
  13. #33
    5BA8
    3,465
    Yeah that thing should have no problem spooling.
  14. #34
    Jul 2020
    VIC Australia
    1,180
    Alright fella's, I think i'm getting somewhere now. Overlaid a log with my old genuine Garrett GT3582R. Nearly got it the same. Close enough anyway.
    After pondering this in my sleep last night I think I've got to the root cause of my issue. I'm so used to driving a PD blown V8 that I expect full torque at 2000rpm. And in that car my normal driving rpm is 1500-3000. Going back to a 6cyl I need to realise it needs higher than that to meet my torque delivery expectations.
    I'm going to unlock the converter and see if that makes me feel better.
  15. #35
    1,543
    I would think 3-4 psi from 2500 to the point the knock off catches up would be enough to feel.
  16. #36
    Jul 2020
    VIC Australia
    1,180
    Definitely noticeable. You'll have to educate me here, should I expect the 3584 to spool the same as my old turbo?
  17. #37
    Aug 2021
    867
    LOL Man I laughed hard at this! Carry on...
  18. #38
    1,543
    That post exhausted my knowledge on the subject. I'm just a little fish on here. But since you didn't carry the 3582 any higher, was it out of steam when you stopped the pull?
  19. #39
    Jul 2020
    VIC Australia
    1,180
    Not out of steam but only just hangs on for the ride, duty cycle at 90%. Same boost on the new turbo duty cycle is 30%.
  20. #40
    Jul 2020
    VIC Australia
    1,180
    Ah hah! I'm not losing my mind. Boost vs. rpm is fine. Boost vs time is a WAY different story. Takes 2.5sec longer to hit my boost target. I can't get anymore timing into it. Cams are ball park. I shouldn't have put high comp pistons into this motor.
