Results 1 to 14 of 14
Thread: Gen 2 Coyote, stock cams, VCTI max cam angles
    Mar 2024
    7
    Hi,
    I am across the pond in the U.K and have a Gen2 Ford Performance Coyote. The engine is completely stock but is now running a Motec M150. I have a dyno session next week, does anyone know the max inlet advance and the max exhaust retard angles? Are these angles mechanically limited by the phasers?
    From my research I have concluded following, are these figures correct?
    Inlet:
    • Advance: 20 degrees
    • Retard: 50 degrees
    Exhaust:
    • Advance: 50 degrees
    • Retard: 0 degrees
    Lock out:
    • Inlet: 20 degrees BTDC
    • Exhaust: 9 degrees ATDC
    Many Thanks
    Tom Haryett
    Jun 2020
    788
    What do you mean by lockout? The neutral/deenergized/disabled state is 0,0.
    Mar 2024
    7
    Mike,
    Sorry this is not clear.
    The 20 degrees BTDC and 9 degrees ATDC refer to when max lift occurs with the phaser in lockout/deenergized state.
    Jun 2020
    788
    I see where you got those numbers now. I believe what that means is that’s the actual ivc and evo when the phasers are at 0/deenergized. For comparison, the 3.5 eb ivc for the phaser ranges from -50 to 0 but ivc is 21 atdc at 0. Full advance and full retard roughly line up the same as gen2/3 coyote. Gen1 and 4 are more like ecoboost. Gen2/3 are more like gt500.
    I took apart a gen3 exhaust phaser and believe what you are asking is correct or very close to it. There might be another 5 deg wiggle room but the mechanical stops are very close to the numbers you posted if not dead on.
    Mar 2024
    7
    Is there any chance of piston to valve contact with standard Gen2 cams and phasers? Can I move the phaser all the way to there mechanical stops when on the dyno?
    Jun 2020
    788
    I’m nearly certain the mechanical stops won’t allow pv interference. But don’t risk your motor on my word…
    Mar 2024
    7
    That is the $8000 question.
    I was hoping someone would have logged what advance / retard the Ford control module puts into the cams on a run.
    Jun 2020
    788
    I have a file from a gen2 ford control pack (if that’s what you’re referring to), but it’s in .tec format.
    Mar 2019
    351
    Here is a stock gen 2 control pack:
    Gen 2 coyote control pack.hpt
    Mar 2024
    7
    Quote Originally Posted by B E N View Post
    Thanks Ben
    Mar 2024
    7
    Inlet:
    Max advance: 20 degrees
    Max retard: 50 degrees
    Exhaust:
    Max advance: 0 degrees
    I believe the cam timing events are as follows (I had the exhaust advance/retard the wrong way around in my first post)
    I would still appreciate some confirmation if anyone knows
    Jun 2020
    788
    Your first post was correct.
    Mar 2024
    7
    Everywhere else I have found shows the exhaust cam only ever retarding and never advancing?
    Jun 2020
    788
    In the exhaust cam, 0 is fully advanced and 50 is fully retarded.
