Results 1 to 3 of 3
Thread: 2009 Tahoe
    Nov 2022
    Florida
    29
    2009 Tahoe
    I have a 2009 Tahoe. I flashed with a stock 2009 police Tahoe with a 5.3 tune. Now I get p0606 code and the throttle quits working after a few minutes. The tune was supposed to give better throttle response according to the individual that sent it to me. This is the first gen 4 I have messed with. I figured the police package would be a good place to start. It sorta has similar symptoms to a gen 3 bad tac module but does not have a tac. Any ideas?
    13,565
    Never flash a tune that isn't yours into your computer.
    Flash back to a previous file and see if it runs. If it does just use the compare feature to copy over differences.
    7,643
    There are 8 segments in the ECM, a HPT file only has 6 segments. When you change the OS using HPT it leaves 2 of the old segments unchanged, which happen to be the ones for the electronic throttle. HPT is not able to do a full flash on GM Gen 4 ECMs. You need a GM SPS subscription and compatible J2534 device to flash a different OS into these.
