Results 21 to 40 of 48
Thread: 64 c-10 swap tune help.
    Mar 2024
    32
    That's better. Yep it's rich.
    Start logging Idle Adapt STIT and LTIT.
    Don't forget to clear LTFT's.
    Come up in rpm on the next. Include the revision level in your log filename to clear up any confusion. For example, the last one should have been percy641stHPTFtune_SD1.
    YES SIR,! You are the captain of this vessel, and the muahfuckn MVP.
    I was just now sitting here looking at that log and saw that with the update apparently a lot of things changed. And I added channels. And now I'm going to go back in and add the ones that you wanted and get you another log, hero.
    Mar 2022
    Indiana
    2,954
    The Delphi PN comes back as correct on RockAuto, so I thought it was ok. ACDelco is like you're saying. Confusing. I'll update next revison.
    Mar 2022
    Indiana
    2,954
    Warning: the 17113553 injector is 1999-2000, file appears to have 2001-up injector data in it.
    Data matches a stock file on the repository.
    Mar 2024
    32
    This man is a beast.
    percy641stHPTFtune03.hpl
    Mar 2024
    32
    Quote Originally Posted by lm7regal View Post
    I attempted to reset the long trim fuel table. Let me know how it looks, I'm fairly confident I got a right.
    Also, this was the second log.... I clicked close log instead of save log as with the first one. That's why the coolant temp was so high from jump Street. And on the first log it took it awhile to catch on the first start.
  6. #26
    Mar 2022
    Indiana
    2,954
    Alright this time take it for a drive. Can't get fuel trims to track right if it's just revs.
    Included Spark Retard in the channel list, please.
  7. #27
  8. #28
    Mar 2022
    Indiana
    2,954
    Wait a minute. lm7regal give me these numbers.
  9. #29
    Mar 2024
    32
    I gotta be honest guys, that was a far more anxious first 17 Minutes than I had with my xmax.lol. Found out this bitch is rocking 1 working break. same one leaking fluid.... fugg it, send er
    Perci64stock5.3Idletune1.5_SiriusC1024_Drive 1 (1).hpt
    I gotta smoke....
  10. #30
    Mar 2024
    32
    862 heads
  11. #31
    Mar 2024
    32
    E138 on block
  12. #32
    Mar 2024
    32
    E138 on block
    862 heads
  13. #33
    Mar 2024
    32
    862 heads
    E138
  14. #34
  15. #35
    Mar 2024
    32
    what the fuck? are all the channels showing up for you?
  16. #36
    Mar 2022
    Indiana
    2,954
    Awesome now the VE table is starting to shape up nicely.
    I've now incorporated the correct injector data after Blindsquirrel pointed out the problem. RockAuto threw me off. Injector Planet confirms and so does the variation of the VE table in the low end.
    I think you're not saving your .xml channel file because it keeps reverting back. I need to see injector pulsewidth, IAC, Spark Retard, and the rest like you had it before.
    Log another drive like you did. How's it running?
  17. #37
    Mar 2024
    32
    short drives with actual information
    Short drive.hpllongerdhortdrive.hpl
  18. #38
    Mar 2022
    Indiana
    2,954
    Is this SD4 and LTFT's cleared?
  19. #39
    Mar 2024
    32
    no, I think it was sd2. i had it on sd3, logged it without channels in. I went to go log with channels and it was acting like the torque converter was locked. i just flashed the previous tune and then logged LTFT were reset
  20. #40
    Mar 2024
    32
    driveSD4.hpl
    This is SD4
