Page 1 of 3 123 LastLast
Results 1 to 20 of 48
Thread: 64 c-10 swap tune help.
    Mar 2024
    32
    Good morning ladies and gentlemen, my name is Richie and I'm brand new to the forum. I won't bore you all with the sob story, but I received traumatic brain injury about 10 years ago so everything is kind of fuzzy nowadays.
    I'm trying to wrap up a swap in a 64 C10 stepside. I bought MPVI almost 8 years ago and never got around to tuning anything. (I'm retarded, so I went with Holley).
    The truck has an lm7, high volume oil pump, BTR truck norris, springs, valve seals, shorty headers running to true duals.
    I have been doing some lurking on the forums, but information retention is not my strong suite. Would any of you upstanding citizens have a chance to look over my tune and log file? And I guess hold my hand through the scary woods....��
    **I truly hope that this post does not enrage anybody too badly. I attempted to attach the correct files, but if I messed up.... Your hair looks nice**
    Last edited by lm7regal; 03-27-2024 at 08:35 AM. Reason: edit- I forgot t3h headline info. 5.3/4L60
    Mar 2022
    Indiana
    2,986
    It's basically a stock tune with a few tweaks. Fuel and spark need work.
    Mar 2024
    32
    Thank you for your reply. Yeah the only thing I changed in that tune file was bumping the RPM up on the idle and MAF settings I believe. I'm literally an HP tuners virgin, and I'm assuming that my next step is driving the truck? Did you happen to take a look at the log file, I'm curious how things look to everybody else whenever I revved it a bit.
    Mar 2022
    Indiana
    2,986
    Yeah I looked at it. Like I said fueling is off. You should log injector pulsewidth per bank, IAC counts, mass airflow frequency, and spark retard.
    Mar 2024
    32
    My hero! Ive added all channels but the IAC counts. I cant locate that sumbitch
    Mar 2024
    32
    Okay, this is a cold start from 75* f. It was a bear to start. Poor lil starter
    I believe I have all the channels correct on log, but then again probably not.
    Idle was hanging a bit
    percy641stLog4HPTF.hpl
    Perci64stock5.3Idletune1.5.hpt
    Mar 2022
    Indiana
    2,986
    Injector part number?
    Mar 2024
    32
    17113553
    Dec 2019
    MS
    568
    Quote Originally Posted by lm7regal View Post
    17113553
    Oh my.
    Them poor injectors are already maxed out on a stock 5.3. Adding cam and your going to be 100%+ IDC.
    Mar 2022
    Indiana
    2,986
    Let's get VE done.
    Mar 2024
    32
    Quote Originally Posted by RDF1 View Post
    Oh my.
    MAAAAAN, dont gimme that bad juju. LOL
    Ive read conflicting things about running these with a cam, im trying to remain optimistic. What size injector should i get ordered?
    Mar 2024
    32
    Let's get VE done.
    Thank you sir, ill get to flashing now and post a log
    Mar 2024
    32
    Ok, so apparently my version of HP tuners needs to be updated to open your tune fiile. standby
    Mar 2024
    32
    Let's get VE done.
    Just flashed it, and it fired RIGHT TF off.percy641stLog4HPTF.hpl
    Mar 2022
    Indiana
    2,986
    You uploaded the same log as the last.
    Mar 2024
    32
    I think I got the right log now.
    Mar 2022
    Indiana
    2,986
    That's better. Yep it's rich.
    Start logging Idle Adapt STIT and LTIT.
    Don't forget to clear LTFT's.
    Come up in rpm on the next. Include the revision level in your log filename to clear up any confusion. For example, the last one should have been percy641stHPTFtune_SD1.
    7,799
    Warning: the 17113553 injector is 1999-2000, file appears to have 2001-up injector data in it.
