Hello! This isn't strictly an HPtuners thing but I can't find info anywhere and I assume the knowledge base is here - I installed a AXN 9.5 14b axle from an 09 Escalade in my 05 Yukon XL - easy swap but the wheel speed sensors won't read - does anyone know the signal logic in the GMT900 rears? They're both 55 tooth tone rings, the newer sensor is just smaller, plugs right in. I assumed because it is a passive Hall effect sensor it'd register something but my ABS scanner reads both sensors (new) in a failure state. Anyone seen this before? I'd love to keep my ABS if possible. No source about this axle swap had info about this.
