Page 1 of 2 12 LastLast
Results 1 to 20 of 30
Thread: Knock Knock Knock
    Senior Tuner Lakegoat's Avatar
    Jul 2012
    Florida
    1,472
    Knock Knock Knock
    Last little pull that I did in my backyard had some pretty good knock. 10 degrees. It had been showing about 4.5 degrees, but this last run was A LOT ! Engine is all forged 5.3 with a Whipple, open exhaust---about 40" past the exhaust manifolds with 11" dirt track mufflers. Wideband was showing about 2% rich in that area. Runs great, but I would like to get rid of that knock if it is real. The exhaust isn't hitting anything, but it is dam noisy.
    I richened up the 112 kpa cell that shows 11% lean---blip in the VE table. Fuel pressure is increasing with boost.
    Any ideas? Thanks
    2013 Silverado 5.3, 6L80k 8.8
    Tuning Addict
    Jan 2015
    6,829
    Are you sure your wideband is reading right? I'm just looking at your O2's and I'm seeing near 100 mv with the eq error still showing 1 to 2 % rich. Only time I had this bite me before it was because of the wideband reading 1 full point off. Might be worth checking or even throwing another one in for peace of mind. 300 is a lot cheaper than lifting the heads. O2's are showing 880mv when it was showing all of the knock. That seems more like a high 12 afr than a high 11's. You can even command it 10% richer to see if anything changes.
    ~Greg Huggins~
    Jul 2012
    Florida
    1,472
    I have another wideband. I will swap it and see if it is different. I didn't know to check the O2 mv.
    How does 880 mv relate to high 12 afr?
    Thanks!
    Jul 2012
    Florida
    1,472
    Changed out the wideband--(calibrated it). I only got a blip of the throttle to 6400 and it showed 15% rich. Only one cell. I didn't want to hold the pedal down and hurt it.
    Still had 4 degrees of knock. O2's were at about 930mv. It's running 93 pump octane. Is the boost high enough to need a better fuel? Do you think this wideband is working correctly?
    Mar 2009
    Andover, MN
    485
    That seems uber rich. Id also be curious what your manifold intake temps are. Does whipple have a spot in the manifold to put a sensor? 14ish lbs is probably a little much for pump gas depending on the blower outlet temps.
    Aug 2006
    5BA8
    3,351
    What's the compression ratio? What spark plugs are you running? How new is the engine?
    EFI specialist
    email=[email protected]
    Aug 2006
    5BA8
    3,351
    Your knock sensor initial threshold has been lowered, which increases the sensitivity. I'd put that back to stock (120) and see if it makes any difference.
    With a forged piston engine, if I was confident in the build, top ring gap, etc. I'd have no problem desensitizing the sensors somewhat. But you need to know the compression so you know how much timing should be appropriate. A dyno would be really helpful here.
    EFI specialist
    Jul 2012
    Florida
    1,472
    Quote Originally Posted by ns158sl View Post
    Iat's are in the channels. I think it was about 90 degrees where it was knockkin'
    Jul 2012
    Florida
    1,472
    Compression is 10.7:1
    Spark plugs are NGK Iridium #7 heat range---Gen V heads.
    Engine is new ---only about 15 miles on it. Ring gaps are .026 as recommended by Diamond.
    I will change the knock sensor threshold back to stock. Is 140.000 too much to desensitize?
    Mar 2009
    Andover, MN
    485
    Is the sensor pre or post blower? That is a lot of compression. Im surprised it doesnt ping sooner lol.
    Jul 2012
    Florida
    1,472
    Since the two widebands do not agree, I am concerned that this is not going to be right. The only time the widebands are used is when I am tuning my car. They don't stay in the exhaust every day.
    Jul 2012
    Florida
    1,472
    Iat is in the blower lower housing. Post blower.
    Aug 2006
    5BA8
    3,351
    I prefer non projected tip plugs. BR7EF for that thing. That's what I would put in it.
    EFI specialist
    Jul 2012
    Florida
    1,472
    I had a LS3 that was 10.9 compression with a Magnuson at about 12psi and never had a knock problem. The spark table for this engine is the same one that I used for that setup.
    Jul 2012
    Florida
    1,472
    That's what I used before---your recommendation. These Gen 5 heads take a lot longer plug. I don't know how that short plug would work out??
    Mar 2009
    Andover, MN
    485
    Oh wow. I was surprised the IAT didnt jump after getting into decent boost. Did you try to get the AFR closer to commanded and then pull a bunch of timing out just to see what happens?. Kind of getting sidetracked, but what cam are you running? I can barely get 17 degrees of timing out of a N/A 10.8 ls3 before it starts losing torque, lol.
    Jul 2012
    Florida
    1,472
    I thought I replied?? Don't know where it went
    The Gen 5 heads use a longer plug. Would the shorter BR7's work?
    Aug 2006
    5BA8
    3,351
    Quote Originally Posted by Lakegoat View Post
    No, they won't work in a GEN5 head. You need some Brisk plugs for those. Brisk Sliver Racing I think they're 14s you need.
    EFI specialist
    Jul 2012
    Florida
    1,472
    Cam is CamMotion 230/248, LSA 115.5, Timing 4.5 advance, Intake CL 111.0, Exhaust CL 120.0, .631/.629 lift @1.8, Overlap 8.6
    IAT's will get up to 127 with a longer pull.
    First post shows closer afr's, but wideband is not reading right compared to the second log with another wideband.
    Now I am just head scratching.
    Jul 2012
    Florida
    1,472
    I changed the knock sensor number to 129.. Bad thing is, I don't know if the wideband is correct, so I can't adjust anything til I get a new one. Crap!! I will check to see if the knock goes away but it will still be rich or lean--- who knows. What is a good wideband that doesn't break the bank.
