Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
Thread: Knock Knock Knock
  1. #21
    Aug 2006
    5BA8
    3,283
    I would also recommend some bend after the mufflers. At least a 45. That will help at part throttle keep it from being able to pull air the opposite direction across the O2s.
    EFI specialist
    email=[email protected]
  2. #22
    Senior Tuner Lakegoat's Avatar
    Jul 2012
    Florida
    1,461
    I can do that. Thanks
    Here is a new log with the knock sensor sensitivity at 129---still knocks.
    2013 Silverado 5.3, 6L80k 8.8
  3. #23
    Jul 2012
    Florida
    1,461
    I added 10% fuel from 127kpa up to 255---from 4000rpm to 6800rpm.
    10 degrees knock retard. Looks like I will be shifting at 4000rpm. I guess some better fuel is required? Is any of that octane booster any good for testing---don't want to empty the tank. Grrrrr
  4. #24
    Jul 2012
    Florida
    1,461
    Time for some better fuel. Took out about 3-4 degrees of timing, and left it rich. Still knocks.
    Be back later
  5. #25
    Aug 2006
    5BA8
    3,283
    Have you put non projected tip plugs in it yet?
    EFI specialist
  6. #26
    Jul 2012
    Florida
    1,461
    No, nobody around here has Brisk plugs---podunk Fl. , but I did the 45's on the exhaust and went down to the local parts store and got some "guaranteed" octane booster. It kept the knock down to about 1 degree. Thats about 98 octane.
    Something is switching timing to the low octane table before it starts knock. There is Burst knock, maybe that's it ??
  7. #27
    Jul 2012
    Florida
    1,461
    I reduced timing to 10 degrees at wot, made two runs and only got .4 degrees knock retard on one of them. Now to get my E85 sensor wired up and I will be OK. I reduced the last row of timing from 5600 up to 9.5 degrees, for grins and longer lasting cylinders.
    Thanks!!!
  8. #28
    Aug 2006
    5BA8
    3,283
    I would 100% put some non projected tip plugs in it.
    EFI specialist
  9. #29
    Jul 2012
    Florida
    1,461
    What is non projected for Gen5 heads other than the Brisk that you recommended? Thanks
  10. #30
    Aug 2006
    5BA8
    3,283
    Quote Originally Posted by Lakegoat View Post
    That's all I know of for them. Yes they are expensive. But they work.
    EFI specialist
