Results 1 to 6 of 6
Thread: 6l80 Spark Timing
    Mar 2009
    Andover, MN
    485
    6l80 Spark Timing
    What decides how much timing is pulled during a shift? I know it is TqMgnt but I mean what actually decides the amount vs desired engine torque. Is there a predetermined tq value the trans has that it needs to see/calculate before a shift? Im not also not talking about the Max per gear tq limit. I think I have my VTT APC and MAP tables half assed close via chassis dyno using the dynos engine torque algorithm. I know I can take some TqMgnt out to make it "feel" better. Just curious on if there is a more straight forward method.
    Senior Tuner Lakegoat's Avatar
    Jul 2012
    Florida
    1,478
    I don't know about the calculated torque stuff, but here is what I did to reduce some of the timing dip during shifts. ---Not saying it is correct, but it makes the shifts a little crisper? I have been running my '13 Silverado several years like this and no problems. Where I have -3.75, the stock is -20 degrees. Some people run 0 in those cells. Under Spark, Minimum spark, Base---if you have an E38 in this year range. I couldn't read what your model is on the screenshot.
    2013 Silverado 5.3, 6L80k 8.8
    Mar 2009
    Andover, MN
    485
    2012 Yukon. Yeah I think that is my next thing. I was in-between that and table 15440 to adjust per tq vs rpm.
    Tuning Addict
    Jan 2015
    6,833
    Min spark is what most of us use. Just don't go higher than half your wot spark. I normally set it to 5 that way it's not too much and will still allow other torque management routines to work.
    ~Greg Huggins~
    Aug 2006
    Arizona
    263
    I've seen minimum spark set to full ignition timing in some tunes i've opened. Yikes.
    2009.5 PBM G8 GXP M6 W/Roof-Self tune, OBX LTs, Kooks axleback, LSA blower, cam,
    Monster LT1-SC clutch, flex fuel, 12 psi [email protected] 1,800 D.A
    2007 TBSS-Self tune, bolt ons [email protected], 1,900 D.A
    1991 GMC Syclone- Self tune/catback 12.8@104, 4,200ft D.A
    Mar 2009
    Andover, MN
    485
    Well I did play with the adder modifier table. So far seems to work pretty well. Kind of hard to infer delivered torque to driver demand on a Gen 4. I finally started over on the pressure and pretty much reduced them to stock plus 5 PSI. Im pretty sure I am getting a bind between shifts. I did do a Fast Learn and overall everything is shifting great. I am going to pull a little more timing out, also.
    As far as the bind anyone have insight on this?
