Chevy Colorado 2010 5.3
Colorado stock trans throttle 100 tuned.hpt
colorado 2010.hpl
When running normal on street it drives smooth but when i make a stop it sometimes drop rpms too low and turns off.
going uphill on normal speed car feels like it cutsoff and drops like 400 rpms and feels like it will turn off any help here trying to calibrate something im new. only changes ive made were to eliminate vvt , eliminate engine diag codes it doesnt have bank 1 sensor 2 and bank 2 sensor 2 (oxy sensors ) so i disabled those codes, speed limiter , electric fans wouldnt turn on by themselves so i changed the relay control tables, startup (P/N and in gear), electronic throttle open rate; pls if any of yall can help me keep my car rpms where they need to im guessing the problem can be my throttle and changed it but it reacts the same. The log i did was going uphill u can notice it cutsoff on a certain point.
Miguel....
