I'm brand new to HPT so bear with me please. I purchased HPT for my sons 2010 Camaro SS. It has 37K miles on it and was 95% built in 2010-2012 by Thunder Racing (Baton Rouge LA) who is now closed. The car had been sitting in his garage since 2014 when my son bought it Jan 2023. All modifications were done by the previous "original owner". He told us that the car had a very reserve tune in it to get it running and needed to be tuned. All we have done to the car to get it running is change the oil, put in a new set of plugs, and replace the (original) battery. That's all it needed to get it running and he has been driving it as is since Jan 23. The car cranks, idles, and runs great although it is real rich at cold startup. He daily drives it to work sometimes and has drove the car several hundred miles in one day with no issues except for being rich at cold startup. We just recently installed an AEM wide band, AEM boost guage, and a line lock. For the first time, we took the car to the track and made several 1/4 mile passes with it last weekend. I was able to log the passes with HPT. (I haven't figured out how to get boost gauge tied into ECM yet so wasn't able to log boost) The car made some good straight decent passes with a best of 11.30 @ 123 with a 1.57 60'. It took us a while to figure out we had the shift at 6000 to stay of the limiter. Also seemed to stall after the 1st to 2nd shift like it was hitting some kind of limiter then it would pick back up ???? We made some passes leaving in 2nd gear and some leaving in 1st. Ended up breaking the rear end after the sun went down and the track got tight. After looking at the data from the passes and looking over the OG tune, I'm thinking the car has a NA tune in it. Like I said, Im brand new to HPT and this type of stuff. I just wanted someone who knows what they're looking at to take a look.
The original owner gave us a folder with receipts from the mods done to it. This is what I know about the car:
2010 Camaro SS Automatic
L99 416 CI (studded top & bottom) Factory cyl heads with DOD & VVT delete
4.07 bore - 7 layer head gaskets
4.00 stroke Manley Crank
6.125 Callies Compstar rods
-10cc dish Manley pistons
Diamond Pistons ring set
ATI super dampner pinned
TCI flexplate
All ARP fasteners
Melling oil pump
160* thermostat
TR6 NGK plugs
Comp Cams Hyd roller
239/251
.661''/.670''
115+2
LS7 lifters
1.29'' OD Comp double springs
Comp rocker arm trunion upgrade
Magnason TVS2300 Kit for the 2010 Camaro
2.80'' drive pully (smallest they make ???)
3.25'' both rear pullys
AEM Boost gauge reads 10.0lbs going down the track ???? (not hooked up to log in HPT yet)
Lingenfelter L710071410 Twin fuel pump system
Siemans Deka 60lb injectors
We just installed a AEL fuel module hat & #6 braided hose replacing the stock plastic tubing on top of tank.
Kooks 2'' x 3'' headers
Kooks 3'' x 2 1/2'' conn pipes w/ cats
Corsa X-pipe
Magnaflow axle back muffler set up OR axle back straight pipes
Both downstream O2 sensors are unplugged
Have AEM WB in place of rear O2 sensor on driver side exhaust
6L90 Trans
2400-2800 PTC lockup converter
zl1 driveshaft
Stock SS differential (currently broke) with 3.27s
Eibach multi-pro R1 Kit on rear with 450lb springs
All other suspension is stock
Factory SS wheels & tires for daily
Drag Set up:
18x4 fronts with Hoosier 28x4 tires
17x10 rears with MT 315 Street Rs
Here is the OG Tune & 1/4 mile logs:
Thanks for any help and sorry about such a long post.
2010 Camaro OG Tune 3-28-24.hpt
