Working on a '58 Impala with a 5.3/4L60E swap. Using an HPI harness, no provision for the factory 4L60E neutral switch on the transmission (driver side plug). ECU is P01 01 Silverado. It appears none of the aftermarket harnesses provide a plug for the 4L60E NSS.
My issue is the ECU in key on engine off thinks it's in 3rd gear, and upon starting the engine thinks it's in 1st gear. It will always utilize the park/neutral IAC settings and never use the drive settings. My choice for idle at the moment is to dial it in for drive and high idle when in PN, or dial it in for PN and idle very low in drive potentially causing some stalling issues.
Engine is modified FWIW. Truck Norris cam, Sheet metal intake. Clearly needs different idle airflow targets for park versus drive. What is everyone doing when they use a swap harness to tell the ECU when it is in park/neutral versus drive? Just wire up a NSS to the ECU and not worry about the connection on the trans? Does the trans connector tell it when you select 3 vs D?
