Results 1 to 4 of 4
Thread: Srt8 jeep won't go into pe mode
    Jun 2018
    609
    `I'm trying to tune in a Jeep SRT8 with a Procharger and it's not getting into Power enrichment? Staying dead set at 14.7 and not coming off of it. What am I missing?
    MIGUELS.07JEEP.PC.007.hplMIGUELS.07JEEPSRT.PROCHARGER.007.hpt
    Nov 2022
    Nebraska
    6
    I looked at the log, I'm not a professional. PE wont kick in until pedal hits a certain voltage. Looking at the tune its 3.1v, which represents what the logs show. There was a short time when PE was actually commanding a different EQ , but i wasn't sure as i didn't see a wide band.
    I had a similar issue on my turbo wrangler. You can lower the WOT Pedal Threshold a bit to hit PE earlier. I've also read of others multiplying columns of the Power % Requested by certain percentages.
    Mar 2022
    Indiana
    2,957
    It actually did go into PE as commanded. Look in the log at 4:20.
    Like the 402Yeep said, lower the throttle threshold. Increase the enrichment rates.
    It also helps to disable Airflow>Electronic Throttle>Adaption
    Jun 2018
    609
    I thought about lowering the throttle threshold voltage but in my scanner it reading higher than the threshold already. My enrichment rates were higher in previous attempts but I put them back to stock too see if it was causing the issue. Thanks for the help guys
