Hello all! i went to UTI and since graduating (less than 2 months ago) I have not used HP tuners. however i bought a MPVI3 and i am getting ready to flash my 2013 camaro ss.
i have a couple of questions though.
1.
if i go to engine -> fuel -> stoich AFR can i tell the ecu that it is running M85 with a stoichiometric ratio of 7.73?
2.
UTI taught me to use the MAF calibration -> airflow vs frequency to change actual AFR in a N/A engine. but how do i tell the (now supercharged) engine to use MAP instead of MAF? i looked it up and they said it was already wired for MAP. but i cant exactly figure out how to use MAP...
3.
before i went to my camaro's ecu data. i went to the example corvette. and it just had an option for superchargers. pulley ratio and everything. can i do something like that here?
(just re-read this. dumb question. not standalone and the stock ecu would have no possible way of knowing this. my B)
4.
i am planning to start with just a smoothed 15% multiplier on fuel delivery because i want it to run 15% rich above idle. is there a better way to do this?
5.
it has a 110 lb fuel pump and 152 lb/hr injectors. how do i tell the ecu these numbers?
yes i did try to answer these questions on my own. no such luck. any help is VERY appreciated
i will be dyno tuning so i will have actual AFR values to compare to.
