Results 1 to 3 of 3
Thread: AEM wide band reads different in scanner
    I purchased the AEM 30-4110 kit and used it to tune my car 2 years ago. Then i installed long tubes and used a mallet to adjust the xpipe and destroyed the actual sensor so i bought a replacement sensor. It was a bosch sensor for the 30-4110 but when i installed the new sensor the reading was different in the scanner. I can transform the reading if i choose the other AEM option to read the same as the gague but its not the 4110. The 4110 option reads 10 percent leaner than the gague. Should i transform to match the gague? Has anyone else seen this?
    Jan 2014
    Australia
    1,992
    if ur using the correct transform values for the linear voltage, then if u need to adjust it just change the offset value at the end, the + (####) value, all the offset value does is make the actual linear voltage value start at zero or min gauge value so then the scale is correct
    got it thank you
