Results 1 to 8 of 8
Thread: 6.0 swapped 2003 cateye with truck norris cam
    Mar 2023
    8
    as the title states just swapped a 6.0 into a 2003 cateye. stock bottom end with truck norris cam as only upgrade atm. everything is fine as far as starting and the swap is all done but i am trying to get a tune loaded that will make it idle and get enough airflow it needs for that cam. i figured i could just go into the primary VE table and give it like 5% and up the idle slightly and it would idle fine. that doesnt seem to be working great. can anyone give some help as to how to at least getting idling better? or does anyone have a 6.0 tune file i could upload to get it to idle. i am new to hp tuners btw.
    Aug 2006
    5BA8
    3,364
    Post the tune file and a data log. Read the stickies.
    EFI specialist
    email=[email protected]
    Mar 2023
    8
    sorry
    here is the tune file i uploaded to it. i dont have a log file, ill have to get one to upload.
    Dec 2019
    MS
    567
    for starters just add about 3-4g/s to your base airflow table to get it up and running. Raise idle to about 650rpms.
    Mar 2022
    Indiana
    2,971
    This is a 6.0 swap into place of a 5.3 FlexFuel, correct? LQ4 or LQ9? Did you re-use the Flex injectors?
    Mar 2023
    8
    this was actually a 2003 4.3 V6 swapped to a 6.0. the engine came from a 2001 yukon xl, and the harness and ecu are from a 2003 tahoe 5.3 with a 4l60e. harness and ecu need to be 03+ to work in truck. its an lq4 and the injectors are from the 5.3 tahoe.
    Mar 2023
    8
    yeah ill have to get a log of it tomorrow. adding the 15% to the VE table helped but still wants to die, esp when revving slightly and letting off, the rebound it wants to die. also i dont see a secondary VE table where is that? sorry im super new to tuning.
    Mar 2022
    Indiana
    2,971
    Try this out. LQ4 with 33lb Flex injectors. It's setup for SD tuning. Let's see a log.
