Results 1 to 3 of 3
Thread: Channels for LNF
    Apr 2024
    Canada
    4
    Channels for LNF
    Wanted to do some datalogging on my car, however I couldn't find a good channel list to use. Here is a picture my current list:
    Having a mismatch with 2 different boost PIDS. One is Boost[Sensor] and the other is Boost[Math]. The sensor channel is way too high for a KO4 so I'm inclined to trust the math one more, would I be correct in this? Also what is a good channel for AFR? I got the EQ CMD which shows 0.85 but the EQ ratio 1 shows 1.8 which would be leaner than the desert. Also finding TPS maxes out at 80 which is supposedly normal.
    If anyone has a good channel config for an LNF that would they mind sharing it?
    Nov 2017
    1,479
    It no longer has the attached file but you can add the needed channels manually from the screen shots.
    https://forum.hptuners.com/showthrea...NF-Config-File
    Apr 2024
    Canada
    4
    Thank you, figuring some stuff out as I did another datalog and the EQ #1 matched commanded EQ so I'm assuming it was just a glitch.
