Results 1 to 6 of 6
Thread: Need help with stumble and tune for sure.
    Dec 2021
    22
    Hi all, I have a hybrid Gen3-4 car that Im having monster troubles getting to run properly. I am by no means a tuner and I am pretty stupid actually, as I bought this car is a great example. So my knowledge of Hp and tuning is rudimentary, so be gentle.
    Stumbles at around 2-3k rpms and looks lean? I have a AEM wideband installed, but it keeps failing. Got yet another on order.
    2002 C5 Z06 Corvette
    Here are the specs on car:
    ? GM crate LS3 stock engine ? with GM LS2 silver blade throttle body.
    ? LG 1-7/8? long tube headers, no Cats, only 2 forward AC Delco O2 sensors
    ? Vararam Intake, with Gen 4 MAF card type sensor
    ? 525cc FIC injectors.
    ? Racetronix upgraded fuel pump harness. 70psi at idle.
    ? LS3 coil packs
    ? Manual Transmission
    ? Gen 3 2003 engine wiring harness and 2002 PCM with Racetronix adapters for MAP sensors, throttle body, cam and crank position sensors and knock sensors.
    ? (8) Fuel injection adapters to use the Gen 3 engine wiring harness. LS6 knock sensors.
    ? Autoblip installed.
    ? Lingenfelter trg-002 58x-24x box installed on firewall.
    ? 18Lb lightweight flywheel
    ? 93 octane fuel, no additives.
    ? OEM fuel pump
    ? No emissions, No A/C, No ABS, No traction control or stabilitrac
    ? 10% ATI underdrive crankshaft pulley
    5BA8
    3,283
    Why are you restarting the same thread you started 5 days ago????
    email=[email protected]
    Arizona
    472
    Chris@HPTuners; Bill@HPTuners
    close this thread please.
    its duplicate at https://forum.hptuners.com/showthrea...358#post775358
    Dec 2021
    22
    Unable to delete, do I have permission/rights?
    Arizona
    472
    Quote Originally Posted by PBRstreetgang View Post
    no only admin in here can close/delete threads.
    Mar 2022
    Indiana
    2,957
    When you fix the fuel pressure problem I'll get the tune setup for you. Pointless otherwise. Are you looking for a second opinion on it? You won't find it. Need 58psi pressure not 70psi.
