Results 1 to 7 of 7
Thread: P-codes a plenty !
    Tuner in Training WildHorse's Avatar
    May 2020
    40
    Exclamation multiple codes, 2017 Mustang GT
    This is twice now these codes popped up, about a year apart on my 2017 Mustang GT:
    p0010
    p0013
    p0020
    p0023
    p0135
    p0141
    p0155
    p0161
    p0443
    p0446
    Camshaft / O2 / EVAP codes. cleared them, all came back. Immediately. A/F stuck at 14.0
    First time it was a popped #40 engine bay fuse.
    This time, the fuse didn't pop. But looked to have got hot.
    Checked for 5v to all the cams sensors, EVAP, o2, all good. Resistance all good.
    Any idea's ? Shorted o2 sensor maybe ?
    Thanks.
    May 2020
    40
    No thoughts/suggestions ?
    Oct 2016
    Poland
    1,751
    Does it run in fuel mode called FMEM?
    May 2020
    40
    I have no idea. Runs fine other than a loped idle that smells richer than before. The LTFT are adjusting.
    Oct 2016
    Poland
    1,751
    drop a log with hefty parameters
    Mar 2018
    7
    they all share the same 12v power from that 40A fuse , if its not the fuse then its something along the harness (I would look for wires or connectors near exhaust first), also you can try disconnecting each sensor for a particular code to see if the other codes will clear
    May 2020
    40
    *solved*
