Results 1 to 8 of 8
Thread: 2007 Turbo C6 LS2 rich and lean spot on shift at wot
    Advanced Tuner Boosted C6's Avatar
    Dec 2013
    Pennsylvania
    222
    Turbo ls2 vette 6 speed manual has a lean and rich spot on shifts at wot. Seems like wot fueling has some delay even though i changed the PE ramp in rate to 2.
    lean spots on shifts.hpl ls2 turbo mod 18 ve changes new wastegate springs.hpt
    2007 C6 Corvette on3 single turbo kit on a bone stock LS2
    Nov 2006
    2,751
    You will always have a rich/lean tip in or out reading. The engine will be running behind what you already injected. This looks reasonable.
    Do you actually feel a hiccup or something?
    Tuner at PCMofnc.com
    Dec 2013
    Pennsylvania
    222
    Nope it feels fine I just thought it was strange
    Nov 2006
    2,751
    I wouldn't worry about it.
    This is the exact reason why people filter out fast pedal movements when tuning fueling (VE or MAF)
    Jun 2007
    Finland, Europe
    549
    Quote Originally Posted by Boosted C6 View Post
    While I didn't check your log and if you have some free time to spend for testing, you could try to change Transient Fuel Impact Factor. I've had some success with it getting rid of lean spot. Try adding 30% or so.
    Senior Tuner Lakegoat's Avatar
    Jul 2012
    Florida
    1,472
    Why isn't your (closed) VE table populated the same as the (open) ?
    Do you have a boost referenced regulator or is it a dead head setup
    Are you setup for running SD?
    2013 Silverado 5.3, 6L80k 8.8
    Nov 2006
    2,751
    only open is used.
    Jul 2012
    Florida
    1,472
    Only open is used on SD ?
    I was reading on Tech that a guy was going to use two fuel pumps, one on a hobbs, and install a timed relay to prevent fuel pressure drop between shifts ??
