Results 1 to 14 of 14
Thread: help with not idling after stop when coming down from 40mph or higher
    Nov 2023
    25
    i have a 6.0 ls which if you drive easy its ok when you decelerate from above 40mph it will chug and die at complete stop unless you feather throttle at stop alittle then will stay idling but will start right up if dies plz help
    1,472
    As always, tune and log needs to be posted.
    5BA8
    3,269
    FFS how can anyone help without a tune file and data log???? Seriously......
    email=[email protected]
    7,655
    It's a 6.0 LS, aren't they all the same? You guys must not know much about how these things work.
    5BA8
    3,269
    That's why I got this!!!! Muhahahaha!!!!!
    Nov 2023
    25
    Idling concern and running lean
    gary 6.0.hpl
    its also running very lean to lean to drive dont want to hurt anything i have 52psi fuel pressure which is oem specs any help plz
    original tune 6.0_CL_Enabled.hpt
    Nov 2023
    25
    Tune posted sir
    Nov 2023
    25
    Tune and file posted sir
    2,751
    You won't hurt this setup being too lean.
    The drivers side o2 sensor looks suspect. The fueling needs to be gone over.
    Tuner at PCMofnc.com
    5BA8
    3,269
    You have something going on with bank 1. It has the fuel trims pegged at +50%. Need to check the header temps with a temp gun. Might have multiple dead cylinders on that side causing a bunch of raw O2. Bank 2 is not near as bad.
    Nov 2023
    25
    did some testing found plugs were black and wet replaced plugs checked compression have 180 across the board. have no cylinders missfiring and have 52psi fuel pressure and it still buries my fuel trim to positive 50 is there a chance i can ajust my numbers in ve table in this area to lower my trims or not work that way plz help also have no vacuum leaks any suggestions plz
    Arizona
    468
    any suggestions plz
    Every change you make, such as replaced the spark plugs, you need to run a log and post it here for us to see.
    Your tune and your data log needs to be posted.
    Or else we are like slow-poke rodriguez,nothing gets done.
    But yes, altering your VE table, and your MAF, and your timing, and your BRAF and a few others all control how rich it is.
    5BA8
    3,269
    Why are you starting a second thread for the same exact scenario? Stop it. Keep everything in this one thread.
    5BA8
    3,269
    Where is your current data log after having replaced the plugs????
