Results 1 to 14 of 14
Thread: Cast an eye over this please
    Aug 2016
    Swansea Wales UK
    186
    After a 0.2 slower run at the strip i looked and why none of the improvements had worked and found a big power loss through the "new" exhaust system, rectified this with some straight throughs and gained quite a bit. I was using the data from the engine torque function. Realising i need too retune too suit i've had a right memory loss on how to do stuff. If anyone could check i've got this in SD before i alter my tune, many thanks John in wales where no one has a LS
    Gen3 L59/4L60E LS3 cast manifolds, Small Cam change, 2800 Convertor, MPVI, using MTX-L for wideband tuning
    Arizona
    482
    Quote Originally Posted by jsf55 View Post
    John in wales
    top of the morning to ya.
    sorry, typical yank here.
    why dont you tell us more about your vehicle.
    engine, parts used, transmission, stall, gear ratio, cam etc.
    your VE and spark tables are intersting. Not that theyre wrong, just would like to know how you came to using what you have as every engine is different.
    cheers
    Aug 2016
    Swansea Wales UK
    186
    Thanks for the reply, engine build is in my signature, it was a L59 and had a lot of stuff to change over mostly using LS1 info too make it suitable for the hot rod, Diolch yn fawr , John in Wales
    Aug 2016
    Swansea Wales UK
    186
    Damm it !! the MAF was still on. I've zeroed it out ready for another run tomorrow.
    7,710
    Uh, zeroed out what? Do not zero out the MAF table, that has nothing to do with failing the MAF and can create other problems. The tune file has the MAF failed correctly, with the exception of [ECM] 3003.
    Your log has a current P0103, which is what it should have if the MAF is installed and plugged in but failed. If totally removed/unplugged it will have both P0102 & P0103.
    Aug 2016
    Swansea Wales UK
    186
    So 3003 should read 100/200 is thats where i've gone wrong ?
    7,710
    Nope, setting that real low is for 'MAF-only'. Needs to be set higher than it will ever get to.
    Aug 2016
    Swansea Wales UK
    186
    I'll get it all set up for later today, thanks for your help
    Aug 2016
    Swansea Wales UK
    186
    As much as i tried and checked, it always showed the MAF reading something, i looked back at some of the other times i had run VE tuning and found the MAF table zeroed out (2017) i tried it, it worked. It's all much older stuff here as i'm a one man band tuning one car. HPTuners pro 1 with version 4.4 if that makes any difference, too busy out there too go tuning i'll just be sat in traffic for miles
    7,710
    Yes, of course there will still be a Hz reading from the MAF when failed as long as it is still plugged in and still in the airstream. DO NOT log MAF-specific channels when you have failed the MAF in the tune. It can freak things out - you're asking for data from a sensor you've explicitly told the PCM you do not want it to use.
    Your log showed a current P0103. It was/is in speed density. Stop freaking out. You can remove/unplug/depin the signal wire from the MAF connector if you still have doubts.
    There is a channel you can add that will show you in real time if the MAF is failed or not: Mass Air Flow Sensor State. And remove the other PIDs that are reading MAF data (Cylinder Airmass, Dynamic Airflow, Volumetric Efficiency Airflow, etc, are calculated, not direct readings taken from the MAF).
    Aug 2016
    Swansea Wales UK
    186
    Many thanks, so it won't skew any info for VE tuning although it's logging? No harm done as I still have all the info from yesterday so I'm one stage closer to fetching the table inline
    7,710
    Did you miss the part about 'do not log MAF channels when MAF is supposed to be failed'?
    Aug 2016
    Swansea Wales UK
    186
    Good point, slaps hand, i can remove that from my channel listing for now, many thanks again
    Aug 2016
    Swansea Wales UK
    186
    Worked a treat, had too good runs out and trimmed it all suitably, more tomorrow as were out for a proper run
