Results 1 to 5 of 5
Thread: Startup File
    Jul 2020
    5
    Startup File
    I have a 2017 L83 with a stock engine and a Magnuson supercharger. I am replacing the engine with a fresh build that includes LT4 injectors and pump and a stage 1 Positive Displacement blower cam.
    The current tune file came with the supercharger through the team a magnuson . What would i need to alter to just get it to fire and run.
    Ive heard it wont even start with these injectors.
    Nov 2006
    2,839
    The canned tunes from those companies are usually not super great.
    BTW. You should read about adding a SCIAP sensor. It makes an absolute tremendous difference in driveablity with a magnacharger or any PD style blower.
    Tuner at PCMofnc.com
    Tuning Addict
    Jan 2015
    6,849
    I know the pump is super pricey, but you might want to look into that too. You can wind up starving the rails with too small of a pump with the bigger injectors.
    ~Greg Huggins~
    Jul 2020
    5
    Will do thank you, I not sure if I will nee one, ive been drivign the truck with the charger for 6 months with no issue.
    I am also running the supercharger .. TVS2650 Magnum GM Truck and SUV L83 5.3L Supercharger System. https://magnusonsuperchargers.com/pr...1-26-53-014-bl
    Jul 2020
    5
    yes I have the high pressure pump. (LT4) I am looking at feedpump options too.
