Results 1 to 3 of 3
Thread: Transmission Tuning
    Feb 2024
    North Alabama
    8
    Transmission Tuning
    I put together a spreadsheet to help me with transmission tuning. I use it to calculate the speed for the RPMs I want the trans to shift at for the various tables as well as handling the torque converter lock calculations. I have options for single or triple disk converters and whether to lock the converter at WOT. I also calculate the inputs for Trans Revolutions/Mile and VSS Pulses Per. I have a sheet for the 4L60E and 4L80E. I have stared at it so long I might have missed something. Anyone want to review it and see if they see an issue?
    TuningTools.xlsx
    Aug 2006
    5BA8
    3,316
    How do you factor in torque converter slip?
    EFI specialist
    email=[email protected]
    Feb 2024
    North Alabama
    8
    As far as which aspect? I considered it for a triple disk where you can lock it early in each gear to prevent reving when normal driving and keep temps down. Nice thing about having a truck based OS is the performance tables. You can set up a normal driving tune to lock up at low rpms and gears and then press the tow/haul button to switch to the performance tables for less lock and more torque production. Does that answer your question?
