Results 1 to 8 of 8
Thread: N/A E-85 timing
    N/A E-85 timing
    I was just curious how much timing you guys are running with e-85 n/a. Im running 26? max timing with 0 knock, and was wondering if i could go more, or do you recomend less
    2019 challenger rt
    k&N cold air intake
    92mm hellcat throttlebody
    ported 392 intake manifold
    ported eagle heads
    Cammotion custom 222/234 cam
    stainless works long tube headers and catless mid pipes
    3' catback with h-pipe & pypes violator mufflers
    e-85 tuned
    3.70 lsd
    Jan 2022
    909
    how much timing it will want is dependant on how much dome the piston has
    *but i doubt it will want more than 26 no matter what is in it
    Aug 2021
    Yorktown VA
    197
    Assuming you are running stock compression and stock specked pistons, ect., I wanna say 28 degrees is about as high as you can go with the 5.7L. If you are running E85 thats testing close to 80% or higher, you could probably get away with trying a run with 28 degreres adv.
    2016 Ram CCSB Forged NA 396ci Stroker
    +2.5cc Flat/Dome Mahle Power-Pak Forged Pistons w/13.2/1 CR on E85
    Forged Manley 4.05" Stroke Crank/Speed Master Valvetrain
    Race Ported Eagles/Titanium 2.12"/Titanium 1.62" Valves
    Custom Cam 235/249 .629/.629 111LSA 110ICL+1Adv
    Ported Holley Hi-Ram Intake/NXpress Hi-Ram NO2 Plate kit w/250 Shot(4 sec)
    Tx Spd 2" Long Tubes/Active Viper Hood/2-Step
    ATI SD w/15% UD/Dual 450 Pumps/Fuel Cell in Bed/Demon 700cc Inj
    3800 stall/Det Tru-Trac/410 Gears
    The station usually reads 80-85%, so pretty good e85. And yes, stock pistons, all work done is in my signature.
    2019 challenger rt
    k&N cold air intake
    ported eagle heads
    e-85 tuned
    3.70 lsd
    Jan 2022
    909
    my buddies 13:1 5.7 based motor only wants 26 degrees on good E
    its in a 2700# dart
    cant imagine yers wanting more than that at what? 4400?
    he is leaving on a brake and at a lot higher rpm than you so maybe cant compare
    Aug 2006
    Arizona
    247
    I've never seen much of a gain on 5.7s after 24 degrees on E85.
    2009.5 PBM G8 GXP M6 W/Roof-Self tune, OBX LTs, Kooks axleback, LSA blower, cam,
    Monster LT1-SC clutch, flex fuel, 12 psi [email protected] 1,800 D.A
    2007 TBSS-Self tune, bolt ons [email protected], 1,900 D.A
    1991 GMC Syclone- Self tune/catback 12.8@104, 4,200ft D.A
    Apr 2024
    Telford PA
    9
    26 is about the max, some of it depends on elevation, closer to see level, and dry air 28 is max and very rarely shows any gain over 24-26
    cam Motion stick GRIND# XA227/375-XA235/375-13.5+3
    I've had that in a few 5.7s good cam, Why did you go with a 222/234 duration ? may I ask the lift ?
    Original plan was to go supercharger, but im going a different route. Also wanted something that pulled good to 6400ish rpms. And i live in florida, so very low elevation, but nasty during summer
    2019 challenger rt
    k&N cold air intake
    ported eagle heads
    e-85 tuned
    3.70 lsd
