Results 1 to 6 of 6
Thread: Throttle pedal dead again
    Jan 2021
    14
    i have a l83 from 2016 in a c20.. The throttle usually works fine, but occasionally it has 0 response and i have to idle over to the side of the road..
    this happened a couple years ago and has been ok since, but now its happening again.. Seems to be when the truck gets wet.. I was thinking its a throttle system ground? is there a system or method to check the ground at the throttle body or pedal to see how well its grounded? its an intermittent prob so i am a bit stumped.. any ideas?
    Tuner CYN_CRVR's Avatar
    Jul 2023
    Los Angeles
    60
    Does it throw a CEL when this happens? If so, the specific code should be a big clue. I ran into a similar issue once with an aftermarket CAI that ingested water and got the MAF wet during heavy rain.
    Jan 2021
    14
    it does have an aftermarket k and n intake on it.. what did you do?
    Jul 2023
    Los Angeles
    60
    In my case, the problem was solved with a water repellent pre-filter wrap, e.g. AEM DryFlow or K&N DryCharger. This would probably only be relevant to you if your filter is behind your grill so that oncoming rain can hit it directly, or otherwise in a location where water can splash or drip onto it.
    https://www.knfilters.com/search/wrap
    https://www.aemintakes.com/pre-filter-wraps
    Jan 2021
    14
    yup... a K&N right in the front prob getting wet.. Its not covered.. Did your car have no throttle too? i am going to read the code, but the maf sensor sounds like it could be the issue..
    Jul 2023
    Los Angeles
    60
    My engine would stumble and fall flat at mid RPM, but I was able to limp home at low RPM. This was with a Mazda, fwiw.
