Results 1 to 12 of 12
Thread: Gen 3 5.3 Stock Learning gas tuning
    Sep 2023
    Arizona
    10
    Hello all i have a 2001 suburban with module P01, pulled my stock file, updated the speed density OS, did some data logging so far. Right now my fuel system #1 is at CL-fault, I am wondering if fuel system #1 and #2 on data log channels correlates to the B1 and B2 or oxygen sensors
    Arizona
    476
    Quote Originally Posted by Tow Mirrors View Post
    until you post up your tune and log we cant do anything to help you at all.
    also you need to tell us about your engine, and other modifications you have done, such as exhaust.
    you paint the picture for us to help you.
    and why are you messing with SD os?
    13,571
    My exact question, why would the first thing you do be adding the speed density OS?
    Sep 2023
    Arizona
    10
    Will add log file in the morning, and I try to update all the OS before doing any tuning
    Sep 2023
    Arizona
    10
    Figure it’s best to keep things up to date, then again I am new to this, tuned my cummins once after an engine swap to the best of my ability now trying to learn gas
    2,751
    Some of the early SD OS's keep the MAF from ever working even if you have it setup to do so.
    I think you'll see CL fault if there is a MAF failure.. which might be related to the SD OS
    Tuner at PCMofnc.com
    405
    2,333
    Changing to a COS doesn’t keep things up to date. It changes it to a different type.
    Sep 2023
    Arizona
    10
    File Posted below
    5BA8
    3,297
    Fuel trims are working. You're logging way too many pids. Need to cut out 75% of them at least.
    email=[email protected]
    Sep 2023
    Arizona
    10
    I since have made a better channel list but for that first test was seeing what was available and logging
    1,495
    Gen 3 can only handle so many channels at one time.
