Results 1 to 12 of 12
Thread: Wideband Maf A/F Ratio error % Won't Work?
    Apr 2006
    Grande Prairie, Alberta
    110
    I'm trying to get the Maf - AFR error histo to work. I added my wideband to the table and it works but nothing shows in that histogram. Wideband histo and command a/f histos work though. Here's a log and config that I'm playing with.
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,266
    works fine for me
    even using your config.
    Apr 2006
    110
    I tried to log it after, that's an old log that I posted. It's histo #3 that doesn't work.
    HP Tuners Support
    (foff667)
    28,266
    get to know your filters my friend.
    You have a filter of Throttle position>99%
    Yet your TPS only hits 88% at WOT which means its filtering out EVERYTHING.
    You'd need to log ETC Position to get 100%
    Apr 2006
    110
    Quote Originally Posted by foff667
    Actually I never set that up, thats how it was and I'm not really sure how to use the filters yet. So do I just need to take the filters out on that one? Shouldn't my A/f error % show up in histo #3? And that's what I use for tuning the maf?
    HP Tuners Support
    (foff667)
    28,266
    if you have filters in there that will never be met there obviously wont be any info showing.
    Do whatever you want...take out the filters, adjust them, or log the correct PID's, I can't make that decision for you.
    Yes thats what you'd use for the maf.
    Apr 2006
    110
    Well I'm just asking the correct way to set up the histogram to calibrate the maf with a wide band. I've never done the maf or ve with wideband tuning so I need a little guidance as I don't really understand the way the histos are set up. Here's another config. Please just let me know if there's anything else I need to tune the maf and ve with my wideband. Thanks!!!
    HP Tuners Support
    (foff667)
    28,266
    correct way to be to use that histo with the correct PID's being logged in the table display & filters to give you accurate info.
    Apr 2006
    110
    OK, thanks. I'm not sure what to filter out but I'll look into it.
    HP Tuners Support
    (foff667)
    28,266
    with ls1 fbodies i just filter out everything below 4000 rpms & 99% tps and determine what info to use looking at my cell counts.
    Apr 2006
    110
    Oh, Well I'm looking to tune the VE table and Maf freq hz table, not WOT, if that's what your talking about. I'd want to log every throttle position and every rpm up to a certain pont right?
    HP Tuners Support
    (foff667)
    28,266
    you cannot tune them at the same time...so figure out what you want to tune & then do so...if your using a wideband they can be tuned at wot
