Results 1 to 7 of 7
Thread: Mismatched Numeric Data Ranges
    Aug 2021
    534
    I was doing some experimenting and changed some of the prediction coefficients and now I would like to to change them back to stock (as seen in the screenshot), however, the OEM calibration exceeds HPT's range of +/-1000. Is this a defect on the HPT side? I am scared to click yes to the warning message.
    My Tuning Software:
    MAF Assistant
    EOIT Assistant
    1,499
    I have to admit I would follow the instructions and contact support.
    Jul 2020
    VIC Australia
    1,168
    Yeah, they're bugs. Wind them out. Min: -3.4E+38 Max: 3.4E+38
    7,694
    CTRL+L, find one from before you made the change, right-click & Open in New Editor and save.
    7,694
    This happens in other tables as well, depending on year/platform.
    2,751
    yep, that one always confused me.
    Also some gen 3's will have 12xx in some max torque tables from the factory when the editor only allows 640.
    Tuner at PCMofnc.com
    7,694
    At least I think I understand the reasoning behind exceeding the max on that one, it changes the shape leading up to/after the peak and the dwell time at 194F, even if the value the ECM uses never goes over 2.000.
