Results 1 to 5 of 5
Thread: 2015 Challenger Will not shift into 1st gear
    I have a 2015 Challenger R/T and it won't downshift to 1st gear until the car is stopped. I was curious what a safe RPM to have it downshift to when coming to a stop (0% Throttle).
    I have all the spread sheets and I assume keep it under the upshift RPM.
    I am not the guy that tunes transmissions, our username is similar. If yo message me about I am not replying anymore.
    Aug 2023
    SoCal
    471
    Quote Originally Posted by dodgeboy View Post
    Assuming it is equipped with an 8HP, there is no low sprag, so you really don't want it to go back to first until you are stopped or it will have an unpleasant downshift clunk.
    Robert Moreau
    TransGo
    Aug 2021
    Indianapolis Area
    179
    The max value is around 20% lower than upshift point.
    Example:
    - 1st to 2nd: 500 rpms
    - 2nd to 1st: up to 400 rpms
    In case done correctly (shift pressure, shift timing, torque management, torque converter), it will be good and safe.
    DodgeBoy.
    YouTube: https://www.youtube.com/@dodgeboy2785
    Quote Originally Posted by TransGo Robert View Post
    Thank you
    Quote Originally Posted by DodgeBoy_8HP View Post
    Example:
    DodgeBoy.
    Thanks, I'll look into it
