Results 1 to 15 of 15
Thread: Flex fuel feedback
    May 2021
    Between Florida and Michigan
    94
    Flex fuel feedback
    I've attached a stock/oem file with enabled flex fuel, from my 2018 base Ecoboost Mustang.
    Can you take a look at it and give me a little feedback?
    Thanks!
    Advanced Tuner skylinedan's Avatar
    Sep 2019
    Toledo Ohio
    277
    You have a stock intercooler ?
    Jun 2019
    Wisconsin
    361
    This isn't my latest tune, but I don't think I've changed any of the flex stuff since and it's been working pretty well... Other than the occasional time when fueling up and it thinks the AFR is 11:1 for a few miles then settles into 13.5 to 14:1 where it should be (our 93 here is usually 10% alcohol).
    https://forum.hptuners.com/showthrea...l=1#post729163
    I've only tested it up to about 35-40% alcohol mix, I didn't notice it leaning out, so the fuel system *might* support more, but I didn't want to push it.
    Sep 2019
    Toledo Ohio
    277
    I've heard people going 50%, but others say the stock pumps are good to 40%. I'm on E30 now, but might be closer to 40% with this second tank. Be nice when I get my Fuelit sensor on the car, I'll have a better idea of what I'm burning, and not having to go of what I put in the tank so much.
    Dec 2015
    Miami,Fl.
    294
    Quote Originally Posted by skylinedan View Post
    What's your ratio right now? I pump 3 gallons of e85 and 7 gallons of 93 to get E40...
    2023 Ford Maverick 2.0T AWD
    Sep 2019
    Toledo Ohio
    277
    Last tank I did 6 E85 to 10 93. AWD Fusion tank is 18 gallons, but you still have 2 left when your at zero miles left. It's not gonna be a 100 % accurate I know, but this is what most all the Fusion guys go with. Some say 6.5 gallons to the rest 93, that might be about right if were talking an empty 18 gallon tank.
    May 2021
    94
    My Mustang has bolt-ons, but I backed out all the non flex fuel electronic modifications to make the data universal for everyone, regardless of modifications.
    May 2021
    94
    Thanks for the link! I'll dig into your information when I get back to my laptop!!
    May 2021
    94
    I have a fuel-it setup, they work pretty nice.
    May 2021
    94
    66% ethanol from the pump.
    May 2021
    94
    In the past, when I was targeting a specific percentage, I used VP X85 and 93 octane pump gas and the results were consistent (competition only).
    This time, I'm trying to use what they sell at the pump.
    PS: Testing is being done with my my port Injection disabled, auxiliary w/a Intercooler bypassed, turbocharger boost reduced to 20 lbs, single 3" fresh air intake.
    Sep 2019
    Toledo Ohio
    277
    Yeah, that's what I've been told. I'm just waiting on having some extra cash for it, had a guy on our Fusion Sport forum selling one a while back, but of coarse I didn't have the money, LOL. The whole E85 thing is interesting, been other guys that had the same results after putting a Fuel-it sensor on theirs. I don't think anyone sells true 85% ethanol, seems like they are all low like that.
    How are you adding timing for your additional ethanol content? My F150 wanted 6 more degrees on E30. I found that flex fuel doesn't work in any ecoboost application. Tuners won't do it for a good reason.
    Sep 2019
    Toledo Ohio
    277
    Works fine enabled, but it takes a lot of tweaking to get it dialed in. Timing is up around 6 to 8 degrees, all depends on what part of the table were looking at.
    Jun 2019
    Wisconsin
    361
    The ECU is always monitoring knock, if it can add more timing, it will, if there's too much knock, it'll pull out.
    At least on my Mustang anyway, in high load there's always some knock, probably 2 degrees correction typical. So on 93 (US) there's head room for higher octane fuel to allow more timing.
    It's not a direct "more alcohol=more timing" map, the ECU will add more timing *if* it can. It just takes a bit of time to do it safely, which I like.
    If you want, after switching to your alcohol mix, reset ECU adaptations, that'll force knock timing relearn from scratch and it should add timing in faster than it would "naturally" on a mature car (something daily driven).
    As I see it, the flex setup works just fine for what it is. I would rather it be a direct alcohol measurement instead of the inferred setup... But it does work.
