Hello all, I live in brazil, and started this week the process of learning and tunning my car.
I have past experiencies with programable ECUs (fueltech/motec) but this mercedes tune i got with HPtuners mpvi3 interface is really diferente from all I have seen.
My goal is e50 tune, so i can get a more cooler and powerfull engine. After it runs smooth with the e50 tune, I will work on getting more boost, my car is 550hp spec in the owners manual, and the boost only go to arround 10 psi max.
I have atatched the stock read from my car, and also the tunned file I achieved in this few days of studing and testing.
In the fueling side, the best I managed is upping the "injector pulse multiplier" by 15% (x1,15), and the injector slope by 1 point ( from 0,018 to 0,019) this made the car ok driving arround slow, but at WOT it is too rich by the logs.
I need to correct fueling for the cold part of operating, like a morning start , it happened today and car car almost stalled sometimes, misfiring, must proprably from a lean condition when car is cold, as etanol mix need much more fuel in this warn up period.
Can some share some tips on this cold ECT fueling, where can it be adjusted?
And the high end boosting fueling?
I also noted that there is little ECU information I can get with the MPVI3/scanner for logging, most of the o2 and lambda info seens to be calculated, not actual, am I wrong? Should i install a third part lambda sensor for unning this car, or can i rely on the lambda from the vcm scanner/ECU ?
Thanks in advance, and hoping to get some orientation.
