Results 1 to 2 of 2
Thread: 2002 4.6 2v ecu swap
    Oct 2023
    15
    I have a 2002 4.6 2v Expedition which is not supported by HP Tuners. Question is, will a 2002 4.6 2v Mustang ecu, which is supported, plug into the Expedition wiring harness and allow me to tune my Expedition?
    Advanced Tuner Lost0187's Avatar
    Oct 2021
    Canton Ga
    237
    So you maybe able to do this easy but a lot of times there are some differences in the wiring going into the PCM ad sub systems this is more true as you get into 2005 and up ford vehicles. I can take a look at the wiring diagrams and see what if anything is different. You have a 2002 4.6L 2V expedition you can most likely do a 2002 F150 4.6L 2V update and have everything working properly easier than the mustang since the trucks and SUVs share more similarities. Now with the Expedition make sure you have a 4R70 I know some of the 5.4 2V and 4V Navigator/Expeditions used the 4R100 transmission if im not mistaken. Now you may be able to run a 4R70 off a 4R100 calibration but try to keep everything matching. Just let me know if I can be of assistance I'll try my best to help also double check HPT doesn't support the 00-02 Expedition 4.6 2V they are always adding support and if you contact them directly they might be able to get your calibration supported.
    King Ranch Expedition 5.4 3v 6R80 Coyote PCM , M112 Blower, Kooks Long Tube Headers, Green Cats, Aeromotive Regulated Return Fuel System, ID 1000 Injectors, Custom Interior Wiring, Track Apps, EPS mode adjustable, +6 Blower Pulley w/ Innovators West SFI Balancer, Afco Dual Fan ZL1 Heat Exchanger, Flex Fuel E85 0-60 5 secs 12.0 best quarter mile time.
    14 GT500, 13 Mustang Custom, 03 Aviator 4x4, 16 Navigator Reserve 4X4
