Results 1 to 15 of 15
Thread: 2010-2012 Cummins Do Not Use HP Tuners to Read ECM
    Sep 2023
    432
    I know that no one will find this and read before they purchase HP Tuners and attempt to read the ECM on their truck until after the fact because that?s just what people do. But do NOT use HP Tuners to read your 2010-2012 Ram Cummins. There are far too many issues causing people?s trucks to get stuck in a no start state. Even the 2013+ carries a lot of high risk of the same thing occurring. I see it happening at an increasing rate and have been starting to get a lot of emails of people getting stuck in the position of a no start state on their truck and seeking help.
    Good chance that HP Tuners will either delete this post and/or ban me over this post. But wake up and fix your shit!
    Sep 2023
    432
    I can/do provide stock tune files for the 2010+ Cummins for $50, all I need is the VIN and a picture of the Cummins sticker on the ECM. For anyone that find themselves in the no start situation after attempting a read of the ECM with HP Tuners without doing your research beyond what is just the “cheapest”, providing a stock tune file for you won’t help you unless HP Tuners can still communicate with the truck, which it most likely will not and you will need to have a bench flash recovery of the ECM and a bench flash recovery is something I cannot provide at this time for anyone needing it.
    Just because the initial upfront cost, the cost price of the device itself is cheap and possibly others telling you the HP Tuners is the best, that is NOT the case for the 2010+ Cummins. It has failures on reads and writes all the time on many many trucks. Buy cheap, you get cheap.
    Feb 2024
    22
    I have first hand experience with this issue on my truck. Luckily I have the tools fix it.
    Maybe I should build a bench flash rig and try to help other people too.
    Aug 2024
    What tuner platform do you recommend if i plan on doing a lot of tuning and mods on a lot of different dodge trucks? EFI Live? do you sell hot tunes for EFI live?
    Sep 2023
    432
    I personally use EFILive
    Sep 2022
    Jim P 2.0 I need the tune to fix my truck i used hp tuners on my 2011 dodge ram 5500 and it won't start how soon can you help me fix it I will pay
    Sep 2023
    432
    You need to be able to bench flash the ECM
    Feb 2024
    22
    Quote Originally Posted by Jmctaggart93 View Post
    Did you get this figured out? I may be able to help.
    Dec 2020
    11
    I just found this post AFTER having this issue of course because I didnt know it was a thing. Im sure Ill have to bench cal but would like a base cal anyway so I can do what I need to once I get it straightened out
    Oct 2024
    5
    Yeah, same here, I was looking and now after i have a big paperweight I find this... I read a 2013 earlier that day with no problem, Didn't see the 2010 to 2012s were such a problem.
    Sep 2023
    432
    Even the 2013+ can be a problem at times, on occasion even doing a write can be a problem at times. 2010-2012 a pure no go for doing a read on with the ecm on the vehicle. 2013+ if it has an EFILive CSP tune written to it, gonna run into the same situation as well.
    Dec 2008
    Houston, Texas
    130
    Is this still a on going issue with these trucks?
    Sep 2023
    432
    Of course it is
    Jul 2023
    5
    Quote Originally Posted by Jim P 2.0 View Post
    I can/do provide stock tune files for the 2010+ Cummins for $50, all I need is the VIN and a picture of the Cummins sticker on the ECM. For anyone that find themselves in the no start situation after attempting a read of the ECM with HP Tuners without doing your research beyond what is just the ?cheapest?, providing a stock tune file for you won?t help you unless HP Tuners can still communicate with the truck, which it most likely will not and you will need to have a bench flash recovery of the ECM and a bench flash recovery is something I cannot provide at this time for anyone needing it.
    Could you do a 2007.5 6.7 cummins g56 manual trans? Or if you know a way to get past the tune locked ecu
    Sep 2023
    432
    2010+
