I have emailed support, but maybe someone else can help.
Let me start with I have flashed the car successfully many times.
I went to write a calibration, clicked begin. I noted the key wasn't in the
run position so I moved the key into the run position while it was connecting.
I got a can't locate VCM error and the car will not start now.
What I have tried so far:
1)I have tried a read entire, write entire all have the same can't connect to
VCM error.
2) I have tried to reboot my laptop, I have tried another USB port
3) I have checked the pin 16 on the OBDII port and it has +12V
3) I have checked the fuse for the OBDII port and it's ok.
When I connect the busy light flashes On (4 seconds off) On again.
I was able to get the car to start and run if I pull the pcm fuse and reconnect
it. I know thats not the best course of action but I had to get the car
started.
I have a scan tool that works fine, but I can't connect with the VCMscanner either.
It looks like it's working and errors out on getting vcm info.
Help!
