Page 1 of 2 12 LastLast
Results 1 to 20 of 40
Thread: I am needed help
    Jul 2021
    canada
    24
    I am needed help
    Hey guys its me shaune from calgary alberta
    I recently got a new Colbalt 2007 with a used engine 2.0 supercharged i was having issues with the car so i slowly installed all part below after the new engine was installed that i ordered used with 45k on it
    the car was having issues while going into boost it just boggs out no power but builds boost to 80kpa and stops all parts below was double checked and all value readings was good but did not fix the issue
    If i drive the car under boost meaning in the -kpa it drives fine the car idles fine to only when you get on it this happens
    Just wondering if this has happen to anyone else
    New timing system Triple checked
    New spark plugs
    New fuel filter
    New Laminova core seals
    New injectors
    New fuel rail
    New sensors and plugs
    New manifold gasket
    New intake manifold gasket
    New fuses
    New vacuum Lines for supercharger
    New clutch
    Everything is new
    i will add the tune in the car and the current recording
    new recording with bogging.hpl
    Shaune Latest ECM - 1.0.hpt
    I cant figure this out please help
    Tuning Addict
    10,887
    All those new parts are suspect until proven otherwise. If it came into my bay I would request that all the original, old parts be put back on before beginning anything and if that couldn't be done, I'd refuse it. That's way too many unknowns for even someone highly skilled and with lots of experience.
    If it turned out that none of those new parts were defective right out of the box, or counterfeits, you'd better go buy a lottery ticket cause you're the luckiest mofo I've ever seen.
    Jul 2021
    canada
    24
    My bad i made it sound like the issue happened after i installed all that stuff. thats not the case ill reword my main post
    Tuning Addict
    10,887
    Doesn't matter if it was before or after, the way it is now is the way it is. How many of the replaced parts do you figure were actually defective? - compared to - How many of the new parts are defective right out of the box?
    Jul 2021
    canada
    24
    Okay Well Sorry you have had issues before with defective stuff but me replacing 4 injectors and 2 sensors has nothing to do with the car and what it's doing now. Thanks for the advice i will make sure to keep that in mind
    Feb 2020
    Metro Detroit Area
    389
    A used engine with 45k on it, is not new. How do you know the engine doesnt have a mechanical issue?
    Jul 2021
    canada
    24
    Quote Originally Posted by danmw2003 View Post
    i had the engine brought in and checked before anything was done to it had compression tested leak down test had it fully inspected before i put it in i didnt want to risk anything i paid 2200$ for this service Got the head checked valves seats it came out good wasnt gonna waste my time and they put a new timing chain kit and water pump on
    Feb 2020
    Metro Detroit Area
    389
    So you had the heads off to check the valve seats? Tore it apart to do a timing chain and water pump? If it was a good engine, you shouldnt have had to do any of that.
    Jul 2021
    canada
    24
    you cant trust people these days so i had a friend that does this for a living bring it to his shop and do the full check i wanted to make sure i paid the extra money i got a discount but yes it was checked so i know internally its good
    and sound wasted money but i now know its good for all i know the engine coulda been blasted wasnt gonna chance it
    So the issue i am having is when i stay below 0 and into the minus it drives fine as soon as i go into boost it boggs out
    So i replaced the spark plugs and got the new intake manifold seal and Laminova seals as they was leaking put it back together it was fine for the day and next day back to the same bogging under any kinda boost but drives good under normal pedal staying outa boost i did check to see if maybe the cores didn't seal they are sealed i used a camera to inspect the inside
    Nov 2017
    2,718
    Have you compared your tune to a stock file? You don't list any performance upgrades from stock, so if it won't run on a stock tune, you have a non-tuning problem.
    If it won't run with a stock tune, I would start with verifying fuel pressure followed by confirming part numbers for injectors and map/maf sensors.
    Jul 2021
    canada
    24
    So i dont want to lie but. I have a stage 2 on the car 42lbs disc dephi injectors/ 3.0 pulley After trying all this stuff i decided to put the stock 34 inch pulley and stock green top injectors back in it did the same thing but was misfiring in cylinder 2 and 3 like crazy this was before i found out the luminova seal were leaking badly. i have sealed the cores since then but the car was missfiring with the stock stuff on it when i put the stage 2 back on there was no miss fires but left with the same bogging out under boost issue.
    Recently i noticed that someone took out the internals of the cat so maybe thats whats causing this issue that my stage 2 tune is not tuned for? and when i had everything stock again same issue happening with both stock and stage 2
    I will go hook a fuel pressure tester up and take it for a drive and see what it does be right back
    THANK YOU FOR YOUR time sir i will be back with info
    Nov 2017
    2,718
    I can't really follow what has been tuned for, or if the car has ever ran right with the current setup. It might just need to be tuned.
    Jul 2021
    canada
    24
    so i have a tune that was sent to me for what i have currently stage 2 42lbs injectors and he 3.0 pulley but he didnt tune for no cat as i didnt know the cat internals was removed before i got the car and ripped the old engine out nor was i smart enough to look down the exhaust pipe to see i put the current tune in the car up top on main post and the recording of it
    Nov 2017
    2,718
    So has the car ever ran correctly with the current mods? A tune that was sent to you with no iterations on a modified setup is not actually tuned. It's a starting point.
    Jul 2021
    canada
    24
    Yes it was good for one day i drove the car for about 2 hours and then parked it went back outside the next day and went right back to bogging out under boost. i stopped at a gas station and let it sit for about 15 mins got a drink came out started the car and it ran fine once again but then the next day bogging out again.
    Nov 2017
    2,718
    Not likely a tune issue. Unless you have some ECT table screwed up. Really sounds like a fuel pressure issue.
    Jul 2021
    canada
    24
    Okay just went for a drive with the fuel pressure gauge hooked up at idle 60psi The lowest i seen it drop was 58psi and then at wot after i let off while the car was bogging it jump to 65 and back to 60psi
    would a bad wheel sensor cause this issue of stuttering while driving. also Like i said when i keep it below 0 or at 0 making no boost it runs fine.
    Nov 2017
    2,718
    I can't currently review the data logs. Is it running rich or lean when WOT, either from Wideband reading or narrow band voltage?
    Jul 2021
    canada
    24
    My car yesterday gave me a lean condition code
    Jul 2021
    canada
    24
    gave me a lean condition code on my scanner spark plug tips are white everything is leaning towards a lean condition
