I bought a sandrail with the olds 215 it's been modified large cam, then it has a throttle body which the computer runs, it also has port injection which basically adds up to 10 injectors,it also has a turbo, it has a boost enri cement built into the wiring, does that control the other injectors,I can't tell if the other injectors do anything and does the boost enrichment t have a pulse to operate the injectors
