Results 1 to 11 of 11
Thread: Med 17.5.21 Can not read ECU
    Jun 2024
    6
    Hi guys!
    I recently bought the new HP-tuner mpvi3, installed beta suit, registered my device successfully.
    And it failed to read the ecu. I have loaded it with 2 universal credits and i also try to recync my device.
    It detected my ECU version correctly, but it stops there.
    I have ofc internet in my laptop thru my phone and have my device correctly pluged in.
    Edit: My car is a Golf MK7 1.4TSI 2015
    What have I done wrong?
    Best regards
    Newbie Oskar
    Jan 2022
    18
    Its a 2021 car model ??
    Jan 2024
    30
    What is the error that comes up when you try to read the ECU? It is possible they just do not have the OEM file for your ECU. If you create a service ticket they can often get that taken care of for you.
    Jun 2024
    6
    Sorry, Golf MK7 1.4 Tsi 2015
    Jun 2024
    6
    Uhm, when it starting to read my ECU i can identify it as a med 17.5.21....but after that it says : Faild
    On their website my exact ecu will be find there. So it should read my ecu without problem.
    Aug 2021
    Indianapolis Area
    270
    I would suggest getting in touch with HP Tuners support... [email protected]
    DodgeBoy.
    Email: [email protected]
    YouTube: https://www.youtube.com/@dodgeboy2785
    Jan 2022
    18
    hp tuners support are very bad, not to mention non-existent, they do everything they can to not help you, one year with a med 9.1 with cks problems and refused to correct
    Jun 2024
    6
    I take a support ticket and did get a replay. I need to send them some new logg and info file.
    Gonna do that tomorrow. I keep you guys updated on this matter. Perheps this might be helpfull for some other with same problem.
    Aug 2021
    Indianapolis Area
    270
    Quote Originally Posted by Oskarlb View Post
    Sounds good.
    I have similar issues with a Dodge vehicle... after sharing info file and such, an updated Beta version solved my issues.
    Keep us posted.
    Jun 2024
    6
    Welll, I did try the newest beta version and it was also failing.
    I did try to read my friends SKoda (Med 17.5) to see if the problem was my car or not, and i didnt manged to read out his ecm as well.
    I think there is an other issue rather then my computer/setup. When I did stage 1 by a tuner he could easy do that via my odb-interface.
    I think I have to get a stockfile and use my credit to write it in and there fore "unloock" my ecu. Could that be a solution?
    Jun 2024
    6
    Hey guys,
    A quick update, HP-tuners will take this matter to their expert team.
    Thank you for contacting Support Oskar
    I have escalated this issue to engineering for further research. Issues are addressed based on priority, complexity, and availability of the appropriate engineer. Unfortunately, I can't give you a timeline for when our engineering team will be able to solve this problem. When an resolution is complete or further information is required we'll reach out to you.
    If there is others out there who has the same problem regarding VAG, pleace write to me, and perheps this will get futher in line.
