Results 1 to 6 of 6
Thread: Feature Request: log markers
    Jan 2007
    Cape Coral, FL
    92
    When logging I sometimes run into events, like downshifts at points I don't like, and would like to flag that point in the log so I could easilly find it when playing the log back later.
    Nothing fancy, was just thinking like hitting the space bar to make a mark in the log or flash a status bit. No data entry or anything would be required.
    Nov 2005
    Houston, TX
    3,968
    From the Help Menu:
    Comments and Markers
    During the scanning process you can use the 'C' and 'M' keys to insert Comments and Markers.
    When the 'M' key is pressed, a marker will automatically be inserted into your scan without any prompt.
    When the 'C' key is pressed, a dialog will pop up prompting you to enter in the comment. The scanner will continue to scan while you enter in your comment.
    At the end of your scan session, you can modify the comments and marker descriptions in the Comments and Markers window. This is also where you can give your log file a description and enter in log notes.
    You can also right click the lower table for Insert and Delete functionality or you can use the 'Insert' or 'Delete' keys on your keyboard.
    To modify the comments description, double click the cell for that frame under the Description column.
    Bill Winters
    Out of the LSx tuning game
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    HP Tuners Support
    (foff667)
    28,268
    damnit, im getting slow in my old age hehe
    Jan 2007
    Cape Coral, FL
    92
    Damn, sorry I missed that in the doc...
    Apr 2003
    Almost 2000 feet.
    7,876
    However, it would be nice to have a "Yello Tic" mark on the time slider at the bottom showing where the comment/marker took place.
    Always Support Our Troops!
