Results 1 to 8 of 8
Thread: Stroker blues stalling cam
    Oct 2022
    5
    all looking for help novice here but learning -- 6.4 based 426 hemi big cam, 6.1 intake, 12 to 1 compression, ported thitek heads Apache based, 4000 FTI stall, Kooks long tube green cats.
    tuner can only get 453 HP says cam is horrible (OK maybe so) anyway it seems to run very good and strong to me am I happy not really only have 700 miles on fresh hemi tic failed rebuild. but my issue is this tuner can't get it to stop stalling when coming to idle while driving. this does not happen all the time but 75% of the time. I also won't pass E check due to PO300 code as well as P2098. which I'm assuming has to due with low vacuum and idle stalling big cam.
    tuner wants to drill holes in throttle blade to see if it corrects his, ultimately my issue. Very nervous --Attached is last tune and engine data any help will be much appreciated.'
    Jan 2022
    fountain valley
    1,027
    i have had to drill holes in throttle blades to keep the blade closed enough that it was still in the "slot"
    FI does not have slots
    i have also had to braze up holes drilled by people that didnt know what they were doing
    dont be nervous. dont worry. worry is interest paid on a debt you may not even have
    check yer messages
    Jul 2017
    35
    got a data log by any chance?
    Aug 2021
    Indianapolis Area
    270
    Quote Originally Posted by 426H300SRT View Post
    Definitely tune has room for improvement...
    Do you have a log to share?
    here try this out , flash both pcm and tcm and do a throttlebody relearn and clear the engine and trans codes as well. it should idle better and drive better , also it wont die on you ether.
    Oct 2022
    5
    Cool Log
    Quote Originally Posted by dodgeboy_8hp View Post
    definitely tune has room for improvement...
    Long Log.hpl
    thank you for looking
    Oct 2022
    5
    log
    Quote Originally Posted by MI_Tuning View Post
    thank you for your help damn thing runs strong a little slip in the new converter FTI 4000 i might need to yank that back out and have them tighten it up
    Thanks Skip
    Jan 2022
    fountain valley
    1,027
    a little slip in the converter lol
    yer funny
    post a log of it slicked down on a prepped surface
    *apply release tables need work for the street
    post the track log
    that converter is gonna require 2 separate tunes
