Page 1 of 4 1234 LastLast
Results 1 to 20 of 61
Thread: sd/ol tuned warm up going lean after about 145 degress
    Jun 2023
    34
    lately ive been chasing a lean warm up issue after about 145 degrees, ive added fueling to the ivt table in that area to try to help and doesnt seem to do much. i also added to the vve table in the areas around idle rpm and map to see if that helped and nothing
    2013 Camaro ss ls3 m6
    Gpi ss4 cam, vararam vr drx, afr mongoose heads, highflow cats, long tubes, non adjustable roller rockers, limited shirt travel lifters
    Aug 2006
    5BA8
    5,179
    EFI specialist
    email=[email protected]
    Jun 2023
    34
    do you have any idea what this could possibly be
    Nov 2017
    2,531
    The hint was to post the tune. Always post a tune & log with the question.
    Jun 2023
    34
    my bad, i have updated the post with the tune i have right now.
    Aug 2006
    5BA8
    5,179
    EFI specialist
    Jun 2023
    34
    Yea vve table a little botsched right now Im pretty new at it just been tinkering with it and have to drive it right now, but when the car is warm actually runs pretty good and going down the road I’m with in 2-5 %, just haven’t had to time to mess with idle.
    Jun 2023
    34
    Could anyone tell me how that would effect warm up only after 140 degrees
    Mar 2009
    Andover, MN
    770
    Probably your IVT table. You can see it commanding rich until you hit the threshold and everything is (1)'s. Put it back into closed loop, put the IVT back to stock.
    Have to dial in the main fuel table before you play with all the "adders" to fix your "issue"
    Jun 2023
    34
    I’ve got a closed loop tun I throw in it when I drive it long distances, but was watching the wide band on warm up and it would surge till it got to 190 then run ok so I went open look to try and track it. While idling warm wide band slowly goes Rich and cruising areas were almost spot on. I know the table looks lean in that area but when idling it’s rich. Any ideas on why that is
    Jul 2020
    VIC Australia
    1,511
    Aug 2006
    5BA8
    5,179
    Quote Originally Posted by Stealthy93 View Post
    Put it back in closed loop. Open loop tuning is dumb. The PCM is smarter than you and better at its job than you are.
    The VVE is abnormally low in the idle area and it's a ditch or valley where no matter which direction it moves it's always up. That's just incorrect.
    You've never mentioned the vehicle mods but I'm ASSuming it's the car in your sig with a stage 4 cam. And for that matter, you don't mention WHO'S stage 4 cam so the specs can vary pretty widely.
    EFI specialist
    Aug 2006
    5BA8
    5,179
    Quote Originally Posted by ns158sl View Post
    This right here. It has to be done a specific way. You have to dial in your primary airflow tables (MAF/VVE) at operating temp, then go back and adjust your modifier tables after.
    Your VVE is not properly dialed in. I can tell by the shape.
    Need to put it back in closed loop and use the fuel trims to dial it in. The fuel trims will lead you.
    EFI specialist
    Jun 2023
    34
    Ok I’ll try that, is there any formula that I need t use to filter out cot and dfco while logging to filter out the lean and rich spikes for cats and deceleration for vve logging and do I use narrow band or wide band for logging. Also updated my sig that is the car I’m working on my bad guys.
    Also is there any way I could log a possible leaky injector, vacuum leak, or valve no closing all the way with out have to physically check them thanks for the help
    Jun 2023
    34
    Bump
    Jun 2023
    34
    So I use long term fuel trims to paste into vve tables or do I need any formulas
    Also is there anyway to tell by scans if I have a vacuum leak or valve held opened
    Nov 2017
    2,531
    Valve held open would cause a miss. Vacuum leak will be hard to determine from log since it isn't already dialed in. But if you think you have a vacuum leak at this stage, you need to confirm that you don't before you start dialing it in.
    Jun 2023
    34
    hey thank you for all yalls help
    The only miss i have is low rpm high load which shows its face during take off i figured that was due to the cam and the factory rear end but not sure
    I did a smoke test and it showed a small leak but i didn't see where checked all over engine bay i figured maybe it was what was getting by the valves, should i loosen rockers and retest. also are there any vacuum lines inside the car that could be an issue if rat chewed
    I attached 2 logs below one is warm up the other is a quick drive both of same run
    my main goal is to fix warm up issue and idle portion of vve
    At 11:51:25 on the second log is where the miss is there is about 2 or 3 others in there basically at same rpm and load
    24-07-31 11-49-12.hpl
    24-07-31 12-01-03.hpl
    Mar 2009
    Andover, MN
    770
    Log burst knock. Also fix your decel fuel trims or make DFCO more aggressive
    Jun 2023
    34
    Ok I added burst knock but won?t dfco mess with my fuel trims while I?m logging
