Results 1 to 16 of 16
Thread: fuel tuning
    Question fuel tuning
    I am looking for someone that can help me tune my 2005 GMC 5.3 L v8 to get better mpg out of it. we have rebuilt the top end of the engine and now I want to get better mpg out of it. and have faster acceleration and no pedal delay. can anyone help me out?
    Jan 2015
    Arizona
    1,157
    everyone can help you out.
    Do you hptuners?
    If so post a datalog and your tune and lets have a looksee
    ok how do i post the tune and what data do i need to log
    here is the tune on my truck
    Jan 2015
    Arizona
    1,157
    need a good datalog from it as well
    Ok what Data needs to be logged
    Jan 2015
    Arizona
    1,157
    open your scanner, press record and drive for 5 miles.
    post that and we can see things, and or tell you what needs to be recorded.
    If you dont have an idea what i wrote, then we have to go to step one and help you learn.
    here is the log file
    here is a log file if there is any thing not logged that is needed let me know
    Jan 2015
    Arizona
    1,157
    great log, BUT you need to log short term fuel trims bank 1 and 2 and long term fuel trims bank 1 and 2.
    Without those all we can see is your O2s are working, but there isn't any real info gained from the log.
    LTft and StFt once logged, can then be graphed to see lean and rich conditions, and is needed for doing any actual tuning.
    Also i would add injector duty cycle as well to see what percentage of injector youre using. ( https://www.youtube.com/watch?v=qgnIukluIjo )
    here is the new log
    here is the new log
    Jan 2015
    Arizona
    1,157
    here is the new log
    You are lean all over.
    I'd add 10% fuel to the entire VE table, and then start your VE tuning.
    -i didnt check, the maf is failed in this log?
    Jul 2023
    10
    need to add 02 b1&b2, KR
    Quote Originally Posted by bk2life View Post
    the maf was logged
    14,054
    Does nobody else here see a major problem with all this?
    He is commanding an AFR in the 16's just cruising down the road. Regular stoich for pump gas is never that value and the tune file posted above has lean cruise disabled.
    You can't just try and get magic fuel mileage by changing the stoich value, it doesn't work like that.
    And why has nobody even asked what a top end rebuild involved? What is actually done to this engine? Is it all stock or what the hell is going on here?
    the top end is all stock the lifters where replaced so it sounds like you know how to get the right tune for what i am looking for so what do i need to do to get better mpg and still keep the getup and go when i need it
