Please correct me if I am wrong. After alot of reading about this table,,,I gather I need to reset the fuel trims and drive the car and see where the average LTFT values are at.
If for example I find my LTFT average around 8 then the PCM is adding 8 percent more fuel,,,so I need to scale the entire MAF table by 1.08.
Does this mean "Multiply" the entire MAF airflow scale by 1.08?
If so this actually raises the MAF table number,,,which in turn will add 8% more fuel and then should put my LTFT closer to 0?
Do I understand this right? This should help idle and part throttle driving as long as I am not in PE mode,,,,correct?
