GM stage 2 tune and LTFT log -45 to -50, what gives?
wheres the log and tune sir.
2006 SS Cobalt SC
Stage 2 ZZP Cams
Headers, 3.0" Full ZZP Exhaust
60lb inj. Intake.
2.8 Pulley
72# Lb. Supertech Springs
LNF Ext Valves and lashers
Cobre H/E, option B.
Torque Damper
HPTuned.
Bitchin'.
didn't save the log and its a GM stage 2 tune
my guess would be that the trims arent a problem. i have idle trims of -20. as long as u arent loggin any knock or other problems let it do what it wants.
2006 SS Cobalt SC
Stage 2 ZZP Cams
60lb inj. Intake.
2.8 Pulley
Torque Damper
HPTuned.
Bitchin'.
Sorry Im busy and can't seem to find time for the computer. Wouldn't VE adjustments bring the trims back in check?
rather run a lil rich then lean in my book. was it in Sd or Maf.
2006 SS Cobalt SC
Stage 2 ZZP Cams
60lb inj. Intake.
2.8 Pulley
Torque Damper
HPTuned.
Bitchin'.
Are you still runing the stage II injectors or did you put 60's in?
True. MAF.Originally Posted by redhotjamedjimi
Stage IIOriginally Posted by spaz
My first guess is you are using the LTFT sensor and it's factoring LTFT for Bank 1 and Bank 2, since we have a 1 bank engine you need to only use Bank 1 LTFT for your scanning...
I am almost positive it's a scanning config problem not your engine/calibration.. Remove any reference to bank2 in your list of scan'd PID's
Try using this VCM scanner config.
2005 LS6 CTS-V
2010 LP9 SRX AWD 2.8T
SOLD: 2006 Cadillac SRX AWD V6 A5
SOLD: 2005 Cobalt SS/SC Arrival Blue
^ Yes what Zinner says. The default config basically should be junked and redone if you are using a Cobalt, since the default is based on 8 cylinders (I think it's a LS1 config anyway.) These cars use just 1 o2 sensor for the LTFT and STFT so only one bank. Same with Injectors there is only 1 sensor I believe. Good luck
Here is my config also
06 Cobalt SS SC
2.7 pulley
42.5lb Injectors
HPT VCM Suite tuned
Custom SRI
Tuned
13.701 @ 103 Mph
Best 1/4 mile Stock
14.295 @ 102 Mph
02 TURBO Cavy 2200
Finished
Times coming soon
Thanks guys.
