EFI specialist
email=[email protected]
On my Turbo G body with Holley Terminator X it reads 100kpa. Do you think I need to play with the offset on the MAP calibration?
Does this one have a separate Baro sensor? The values you have for 55567257 match what I can find.
https://dsxtuning.com/products/gm-3-bar-map-55567257
Im sorry it doesnt have a barometric sensor on it.
Yes thats the part number
[email protected] - [email protected]
It doesn't have a baro sensor. I should have deleted that channel.
Picture of o2 placement and fuel pressure
I set it back to stock and changed the spark tables and set pe and be but left it in speed density
It might still have a Baro channel, it just uses the data it sees at key on, engine off to fill it in. Does the Baro and Map match at key on, engine off?
The Baro reading is taken from the MAP key on engine off. That being off, as well as the idle MAP reading means something ain't right. If the Linear and offset are correct then there's a problem with the wiring or sensor.
EFI specialist
I'll take a look at the wiring
I checked the 5-volt reference with sensor unplugged and it is 5 volts. I then plugged the sensor up and back probed it KOEO and I'm getting 1.80 volts on the 5-volt reference wire which is number 1 in the plug and with KOEO on the signal wire I'm getting -.80 volts when back probing. At idle I'm getting close to those same numbers.
Yes they match
I figured it out. The adapter that i bought to go from a ls1 to the ls9 wire was broke on the 5-volt reference wire. I fixed it and now its reading 104 kPa.
@edcmat-l1 you were right. It was the wiring. The adapter that i bought to go from an LS1 to LS3 map sensor wire was broken on the 5-volt reference wire. I'm reading 104 kPa now. Thank you so much for your help. It is much appreciated.
Good deal. That should get you closer just having that reading correctly now.
EFI specialist
Can you look at this and tell me why its trying to idle at 165 kPa?
You have the wrong MAP pid selected.
EFI specialist
