Hello all,
I am doing my first engine swap, going from a 4.8 to a 5.3 ls, and I ran into a pickle. I completed the swap, made sure everything was working and everything was wired up correctly. I went to go turn the key over and nothing happened. I checked everything again and tried turning the key over again and still nothing. I tried turning the engine over with the starter relay and the engine turns over and it'll start for two seconds and die after. I have checked every fuse, relay, made sure the engine is receiving fuel, and about every other thing you can think of. The truck isn't throwing a VATS code or anything. I've been in this pickle for a while now. Can anyone help? I appreciate any advice in advance.
